Salta al contenuto principale
LG Front Load Washing Machine Pump Hose Replacement
Cosa ti serve
  1. LG Front Load Washing Machine Pump Hose Replacement, Safety Precautions: passo 1, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Safety Precautions: passo 1, immagine 2 di 2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
    Chiedi a FixBot
    Aggiungi Commento
  2. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: passo 2, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: passo 2, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: passo 2, immagine 3 di 3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG Front Load Washing Machine Pump Hose Replacement, Remove the top panel: passo 3, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Remove the top panel: passo 3, immagine 2 di 2
    • Slide the top panel towards the rear of the device to disconnect its clips.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG Front Load Washing Machine Pump Hose Replacement: passo 4, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement: passo 4, immagine 2 di 2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG Front Load Washing Machine Pump Hose Replacement, Remove the detergent drawer: passo 5, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Remove the detergent drawer: passo 5, immagine 2 di 2
    • Pull the detergent drawer away from the chassis as far as it will go.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG Front Load Washing Machine Pump Hose Replacement: passo 6, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement: passo 6, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement: passo 6, immagine 3 di 3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: passo 7, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: passo 7, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: passo 7, immagine 3 di 3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the control panel: passo 8, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the control panel: passo 8, immagine 2 di 2
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the detergent dispenser: passo 9, immagine 1 di 1
    • Remove the screw(s) securing the detergent dispenser.
    Chiedi a FixBot
    Aggiungi Commento
  10. LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: passo 10, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: passo 10, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: passo 10, immagine 3 di 3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
    Chiedi a FixBot
    Aggiungi Commento
  11. LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: passo 11, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: passo 11, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: passo 11, immagine 3 di 3
    • Remove the control panel, making sure to thread any cables through the chassis.
    Chiedi a FixBot
    Aggiungi Commento
  12. LG Front Load Washing Machine Pump Hose Replacement, Open the door: passo 12, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Open the door: passo 12, immagine 2 di 2
    • Open the front door completely.
    Chiedi a FixBot
    Aggiungi Commento
  13. LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: passo 13, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: passo 13, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: passo 13, immagine 3 di 3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
    Chiedi a FixBot
    Aggiungi Commento
  14. LG Front Load Washing Machine Pump Hose Replacement: passo 14, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement: passo 14, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement: passo 14, immagine 3 di 3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
    Chiedi a FixBot
    Aggiungi Commento
  15. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: passo 15, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: passo 15, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: passo 15, immagine 3 di 3
    • Use your fingers to pull the boot off its lip on the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  16. LG Front Load Washing Machine Pump Hose Replacement: passo 16, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement: passo 16, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement: passo 16, immagine 3 di 3
    • Slide your fingers around the lip of the boot until it's completely separated from the panel.
    Chiedi a FixBot
    Aggiungi Commento
  17. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: passo 17, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: passo 17, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: passo 17, immagine 3 di 3
    • Open the filter panel at the bottom of the front panel.
    • Unclip the filter panel.
    Chiedi a FixBot
    Aggiungi Commento
  18. LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: passo 18, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: passo 18, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: passo 18, immagine 3 di 3
    • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
    • Place a bowl next to the machine.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
    Chiedi a FixBot
    Aggiungi Commento
  19. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the filter trim: passo 19, immagine 1 di 1
    • Remove the screw(s) securing the filter trim.
    Chiedi a FixBot
    Aggiungi Commento
  20. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter trim: passo 20, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Remove the filter trim: passo 20, immagine 2 di 2
    • Pull the filter trim straight off the front panel to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  21. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the lower front panel: passo 21, immagine 1 di 1
    • Remove the screw(s) securing the lower front panel.
    Chiedi a FixBot
    Aggiungi Commento
  22. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the door latch: passo 22, immagine 1 di 1
    • Remove the screw(s) securing the door latch.
    Chiedi a FixBot
    Aggiungi Commento
  23. LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: passo 23, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: passo 23, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: passo 23, immagine 3 di 3
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
    Chiedi a FixBot
    Aggiungi Commento
  24. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: passo 24, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: passo 24, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: passo 24, immagine 3 di 3
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Remove the screw(s) securing the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  25. LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: passo 25, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: passo 25, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: passo 25, immagine 3 di 3
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  26. LG Front Load Washing Machine Pump Hose Replacement: passo 26, immagine 1 di 1
    • Remove the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  27. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: passo 27, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: passo 27, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: passo 27, immagine 3 di 3
    • Use slip joint pliers to pinch the tub to pump hose clamp and pull it away from the assembly.
    • Pull the hose straight off the assembly to disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  28. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: passo 28, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: passo 28, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: passo 28, immagine 3 di 3
    • Remove the screw(s) securing the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
  29. LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: passo 29, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: passo 29, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: passo 29, immagine 3 di 3
    • Unclip the rear panel from the chassis.
    Chiedi a FixBot
    Aggiungi Commento
  30. LG Front Load Washing Machine Pump Hose Replacement: passo 30, immagine 1 di 1
    • Remove the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
  31. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the air dome: passo 31, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the air dome: passo 31, immagine 2 di 2
    • Pull the hose straight off the air dome hose to disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  32. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the air dome: passo 32, immagine 1 di 1
    • Remove the screw(s) securing the air dome.
    Chiedi a FixBot
    Aggiungi Commento
  33. LG Front Load Washing Machine Pump Hose Replacement: passo 33, immagine 1 di 3 LG Front Load Washing Machine Pump Hose Replacement: passo 33, immagine 2 di 3 LG Front Load Washing Machine Pump Hose Replacement: passo 33, immagine 3 di 3
    • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
    Chiedi a FixBot
    Aggiungi Commento
  34. LG Front Load Washing Machine Pump Hose Replacement, Remove the air dome: passo 34, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Remove the air dome: passo 34, immagine 2 di 2
    • Pull the air dome straight off its hose to remove it.
    Chiedi a FixBot
    Aggiungi Commento
  35. LG Front Load Washing Machine Pump Hose Replacement, Loosen the pump hose: passo 35, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Loosen the pump hose: passo 35, immagine 2 di 2
    • Use a Phillips driver to loosen the pump hose from the drum enough to disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  36. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the pump hose: passo 36, immagine 1 di 2 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the pump hose: passo 36, immagine 2 di 2
    • Pull the pump hose straight off the drum to disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  37. LG Front Load Washing Machine Pump Hose Replacement, Remove the pump hose: passo 37, immagine 1 di 1
    • Remove the pump hose.
    • During reassembly, use liquid laundry detergent to lubricate the hose around its tub connection.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Bill Gilbert
Membro da: 06/30/22
40.137 Reputazione
261 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
28.230 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 22
Ultimi 30 giorni: 99
Tutti i Tempi: 2,512
