Salta al contenuto principale
LG Chocolate LCD Screen Replacement
Cosa ti serve
  1. LG Chocolate LCD Screen Replacement, Battery: passo 1, immagine 1 di 2 LG Chocolate LCD Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG Chocolate LCD Screen Replacement, Back Cover: passo 2, immagine 1 di 1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG Chocolate LCD Screen Replacement: passo 3, immagine 1 di 3 LG Chocolate LCD Screen Replacement: passo 3, immagine 2 di 3 LG Chocolate LCD Screen Replacement: passo 3, immagine 3 di 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG Chocolate LCD Screen Replacement, Sliding Front: passo 4, immagine 1 di 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG Chocolate LCD Screen Replacement: passo 5, immagine 1 di 2 LG Chocolate LCD Screen Replacement: passo 5, immagine 2 di 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG Chocolate LCD Screen Replacement: passo 6, immagine 1 di 2 LG Chocolate LCD Screen Replacement: passo 6, immagine 2 di 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG Chocolate LCD Screen Replacement: passo 7, immagine 1 di 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG Chocolate LCD Screen Replacement, LCD Board: passo 8, immagine 1 di 3 LG Chocolate LCD Screen Replacement, LCD Board: passo 8, immagine 2 di 3 LG Chocolate LCD Screen Replacement, LCD Board: passo 8, immagine 3 di 3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG Chocolate LCD Screen Replacement: passo 9, immagine 1 di 2 LG Chocolate LCD Screen Replacement: passo 9, immagine 2 di 2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
    Chiedi a FixBot
    Aggiungi Commento
  10. LG Chocolate LCD Screen Replacement: passo 10, immagine 1 di 1
    • Unhook the ribbon cable using that flat side of a spudger.
    Chiedi a FixBot
    Aggiungi Commento
  11. LG Chocolate LCD Screen Replacement: passo 11, immagine 1 di 1
    • Next, carefully remove the tape from the LCD board.
    Chiedi a FixBot
    Aggiungi Commento
  12. LG Chocolate LCD Screen Replacement: passo 12, immagine 1 di 2 LG Chocolate LCD Screen Replacement: passo 12, immagine 2 di 2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
    Chiedi a FixBot
    Aggiungi Commento
  13. LG Chocolate LCD Screen Replacement, LCD Screen: passo 13, immagine 1 di 1
    • The LCD screen is no longer connected to the LCD board.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 19-46, Regan Winter 2013 Membro di Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Membri
33 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 31
Tutti i Tempi: 1,084
