Salta al contenuto principale
LG Chocolate 3 Keypad Replacement
Cosa ti serve
  1. LG Chocolate 3 Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG Chocolate 3 Keypad Replacement: passo 2, immagine 1 di 3 LG Chocolate 3 Keypad Replacement: passo 2, immagine 2 di 3 LG Chocolate 3 Keypad Replacement: passo 2, immagine 3 di 3
    • Using your index finger lift and remove the battery from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG Chocolate 3 Keypad Replacement, Rear Case: passo 3, immagine 1 di 1
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG Chocolate 3 Keypad Replacement: passo 4, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG Chocolate 3 Keypad Replacement: passo 5, immagine 1 di 2 LG Chocolate 3 Keypad Replacement: passo 5, immagine 2 di 2
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG Chocolate 3 Keypad Replacement: passo 6, immagine 1 di 1
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG Chocolate 3 Keypad Replacement: passo 7, immagine 1 di 2 LG Chocolate 3 Keypad Replacement: passo 7, immagine 2 di 2
    • Carefully remove the rear case from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG Chocolate 3 Keypad Replacement, Side Buttons: passo 8, immagine 1 di 1
    • Use tweezers to remove the music button found on the side of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG Chocolate 3 Keypad Replacement: passo 9, immagine 1 di 2 LG Chocolate 3 Keypad Replacement: passo 9, immagine 2 di 2
    • Use tweezers to remove the volume control buttons on the opposite side of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  10. LG Chocolate 3 Keypad Replacement, Motherboard: passo 10, immagine 1 di 1
    • Use the flat end of the spudger to lift the orange display data cable.
    Chiedi a FixBot
    Aggiungi Commento
  11. LG Chocolate 3 Keypad Replacement: passo 11, immagine 1 di 2 LG Chocolate 3 Keypad Replacement: passo 11, immagine 2 di 2
    • Carefully insert the plastic opening tool between the motherboard and the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  12. LG Chocolate 3 Keypad Replacement: passo 12, immagine 1 di 2 LG Chocolate 3 Keypad Replacement: passo 12, immagine 2 di 2
    • Use your thumb and index finger to carefully lift and separate the motherboard from the back of the phone.
    • Be cautious of the orange display data cable, it may stick to the motherboard.
    • To avoid this, lift the data cable away from the motherboard before removal.
    Chiedi a FixBot
    Aggiungi Commento
  13. LG Chocolate 3 Keypad Replacement, Keypad: passo 13, immagine 1 di 1
    • Open the phone.
    • Keep the phone open by keeping a firm grip on the hinges to avoid any damages to the phone.
    Chiedi a FixBot
    Aggiungi Commento
  14. LG Chocolate 3 Keypad Replacement: passo 14, immagine 1 di 1
    • Lift the orange data cable up so that it is elevated.
    • Gently use a finger to lift the keypad out.
    Chiedi a FixBot
    Aggiungi Commento
  15. LG Chocolate 3 Keypad Replacement: passo 15, immagine 1 di 1
    • Insert the spudger in between the keypad and the phone.
    • Lift the keypad to seperate it from the phone.
    Chiedi a FixBot
    Aggiungi Commento
  16. LG Chocolate 3 Keypad Replacement: passo 16, immagine 1 di 2 LG Chocolate 3 Keypad Replacement: passo 16, immagine 2 di 2
    • Remove the damaged keypad.
    • Insert the replacement keypad.
    • Reassemble the phone after the broken keypad is replaced.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble this device, follow these instructions in reverse order.
Cal Poly, Team 12-35, Amido Spring 2013 Membro di Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 19
Tutti i Tempi: 778
