Salta al contenuto principale
LG CU515 Keypad Replacement
Cosa ti serve
  1. LG CU515 Keypad Replacement, Battery: passo 1, immagine 1 di 2 LG CU515 Keypad Replacement, Battery: passo 1, immagine 2 di 2
    • Use your thumb to press down and slide off the back cover of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. LG CU515 Keypad Replacement: passo 2, immagine 1 di 3 LG CU515 Keypad Replacement: passo 2, immagine 2 di 3 LG CU515 Keypad Replacement: passo 2, immagine 3 di 3
    • Take out the battery by levering it out towards the bottom of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  3. LG CU515 Keypad Replacement, Motherboard: passo 3, immagine 1 di 1
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
    Chiedi a FixBot
    Aggiungi Commento
  4. LG CU515 Keypad Replacement: passo 4, immagine 1 di 1
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
    Chiedi a FixBot
    Aggiungi Commento
  5. LG CU515 Keypad Replacement: passo 5, immagine 1 di 3 LG CU515 Keypad Replacement: passo 5, immagine 2 di 3 LG CU515 Keypad Replacement: passo 5, immagine 3 di 3
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
    Chiedi a FixBot
    Aggiungi Commento
  6. LG CU515 Keypad Replacement: passo 6, immagine 1 di 1
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  7. LG CU515 Keypad Replacement: passo 7, immagine 1 di 1
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
    Chiedi a FixBot
    Aggiungi Commento
  8. LG CU515 Keypad Replacement: passo 8, immagine 1 di 1
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
    Chiedi a FixBot
    Aggiungi Commento
  9. LG CU515 Keypad Replacement, Keypad: passo 9, immagine 1 di 1
    • Push keypad up and out of the phone casing until they separate.
    • Replace with new keypad.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Cal Poly, Team 21-55, Johann Spring 2013 Membro di Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Membri
20 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 8
Ultimi 30 giorni: 32
Tutti i Tempi: 515
