Salta al contenuto principale
LG BP220 Disc Drive Replacement
Cosa ti serve
    1. LG BP220 Disc Drive Replacement, Disc Drive: passo 1, immagine 1 di 2 LG BP220 Disc Drive Replacement, Disc Drive: passo 1, immagine 2 di 2
      • Ensure the device is unplugged to prevent shocks.
      • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
      • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
      Chiedi a FixBot
      Aggiungi Commento
    2. LG BP220 Disc Drive Replacement: passo 2, immagine 1 di 1
      • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    3. LG BP220 Disc Drive Replacement: passo 3, immagine 1 di 3 LG BP220 Disc Drive Replacement: passo 3, immagine 2 di 3 LG BP220 Disc Drive Replacement: passo 3, immagine 3 di 3
      • Unhinge the tabs that attach the front panel to the unit:
      • Two tabs on the disc drive
      • Two tabs on the left and right side of the player
      • Be careful when handling these tabs. They are very fragile and can be easily broken.
      • Three tabs on the underside of the player
      • Pull panel away from case.
      • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
      Chiedi a FixBot
      Aggiungi Commento
    4. LG BP220 Disc Drive Replacement: passo 4, immagine 1 di 2 LG BP220 Disc Drive Replacement: passo 4, immagine 2 di 2
      • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
      • With the front side facing you lift the front of disc drive and pull out to remove.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
UW Tacoma, Team 1-1, Rose Winter 2015 Membro di UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 15
Ultimi 30 giorni: 65
Tutti i Tempi: 9,582
