Salta al contenuto principale
LCD Screen Replacement
Cosa ti serve
    1. LCD Screen  Replacement, Battery Door: passo 1, immagine 1 di 1
      • Remove the M3 x 4mm screws from the bottom of your device as indicated by the picture. using the Philips Head J0 Screw Driver Bit .
      Chiedi a FixBot
      Aggiungi Commento
    2. LCD Screen  Replacement: passo 2, immagine 1 di 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the left side of the device as indicated by the pictures.
      Chiedi a FixBot
      Aggiungi Commento
    3. LCD Screen  Replacement: passo 3, immagine 1 di 1
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the right side of the device as indicated by the pictures.
      Chiedi a FixBot
      Aggiungi Commento
    4. LCD Screen  Replacement: passo 4, immagine 1 di 2 LCD Screen  Replacement: passo 4, immagine 2 di 2
      • Use your Philips Head Screwdriver to remove the M3 x 4mm screws from the camera flash lid as indicated by the picture.
      • Remove the plastic cover from the flash lid by gentle pulling them apart or using the plastic opening tool.
      Chiedi a FixBot
      Aggiungi Commento
    5. LCD Screen  Replacement: passo 5, immagine 1 di 1
      • Fold the lid down in order to access and remove the final M3 x 4mm screw using your Philips Head Screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    6. LCD Screen  Replacement: passo 6, immagine 1 di 3 LCD Screen  Replacement: passo 6, immagine 2 di 3 LCD Screen  Replacement: passo 6, immagine 3 di 3
      • Use the plastic opening tool to pry the back and front casings of the camera apart.
      • Once pried apart use your hands to pull off the back plate of the camera.
      • You will need to apply a little bit of force to remove the back plate.
      Chiedi a FixBot
      Aggiungi Commento
    7. LCD Screen  Replacement: passo 7, immagine 1 di 3 LCD Screen  Replacement: passo 7, immagine 2 di 3 LCD Screen  Replacement: passo 7, immagine 3 di 3
      • Once the back plate is removed twist the battery cover clockwise and it should easily dislodge.
      Chiedi a FixBot
      Aggiungi Commento
    1. LCD Screen  Replacement, LCD Screen: passo 8, immagine 1 di 3 LCD Screen  Replacement, LCD Screen: passo 8, immagine 2 di 3 LCD Screen  Replacement, LCD Screen: passo 8, immagine 3 di 3
      • Gently pull the tab out of the motherboard and then the LCD screen should easily be removed.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team 3-2, Sullivan Spring 2016 Membro di USF Tampa, Team 3-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G2
4 Membri
12 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 19
Tutti i Tempi: 985
