Salta al contenuto principale
Kocaso M750B Display Replacement
Cosa ti serve
  1. Kocaso M750B Display Replacement, Backplate: passo 1, immagine 1 di 3 Kocaso M750B Display Replacement, Backplate: passo 1, immagine 2 di 3 Kocaso M750B Display Replacement, Backplate: passo 1, immagine 3 di 3
    • Pry the edges of the tablet apart using an iFixit opening tool.
  2. Kocaso M750B Display Replacement, Display: passo 2, immagine 1 di 2 Kocaso M750B Display Replacement, Display: passo 2, immagine 2 di 2
    • Remove three 1.2 mm screws from the motherboard using a Phillips #000 screwdriver.
  3. Kocaso M750B Display Replacement: passo 3, immagine 1 di 1
    • Disconnect the ribbon cables.
    • This guide will help you identify what type of ribbon cables the tablet uses and helps you on how exactly to remove different types of ribbon cables. The exact ribbon cables you are looking for are called ZIF connectors.
  4. Kocaso M750B Display Replacement: passo 4, immagine 1 di 1
    • Desolder the connections to the motherboard and the display.
    • When using the soldering iron, make sure to review the safety guidelines provided in the introduction. Work carefully and precisely to avoid any electrical discharge, puncture of the battery, or heating of the motherboard.
  5. Kocaso M750B Display Replacement: passo 5, immagine 1 di 2 Kocaso M750B Display Replacement: passo 5, immagine 2 di 2
    • Remove the display by loosening the tabs surrounding it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 43
