Salta al contenuto principale
Kobo Clara HD Repairs
Cosa ti serve
    1. Kobo Clara HD Repairs, Before starting: passo 1, immagine 1 di 1
      • To power off your device, hold down the power button until the "Powered off" screen appears as shown.
      Chiedi a FixBot
      Aggiungi Commento
    2. Kobo Clara HD Repairs, Back cover: passo 2, immagine 1 di 3 Kobo Clara HD Repairs, Back cover: passo 2, immagine 2 di 3 Kobo Clara HD Repairs, Back cover: passo 2, immagine 3 di 3
      • Stick a plastic spudger into the gap between the front bezel and the back cover.
      • The back cover is held on by small plastic notches.
      • Slide the spudger along the seam to release the back cover.
      • Pry all the way around until the back cover pops free.
      Chiedi a FixBot
      Aggiungi Commento
    3. Kobo Clara HD Repairs, Battery: passo 3, immagine 1 di 3 Kobo Clara HD Repairs, Battery: passo 3, immagine 2 di 3 Kobo Clara HD Repairs, Battery: passo 3, immagine 3 di 3
      • Gently pry up the white battery connector to pop it out of its bracket.
      Chiedi a FixBot
      Aggiungi Commento
    4. Kobo Clara HD Repairs, Screen connectors: passo 4, immagine 1 di 3 Kobo Clara HD Repairs, Screen connectors: passo 4, immagine 2 di 3 Kobo Clara HD Repairs, Screen connectors: passo 4, immagine 3 di 3
      • Flip up the black tabs on the three ZIF connectors to release the ribbon cables.
      • The smallest connector, under the big cable, has the black locking tab facing towards the cable.
      • Slide the ribbon cables out of the ZIF sockets.
      Chiedi a FixBot
      Aggiungi Commento
    5. Kobo Clara HD Repairs, Battery: passo 5, immagine 1 di 2 Kobo Clara HD Repairs, Battery: passo 5, immagine 2 di 2
      • The battery is stuck down with strong double-sided tape and secured by a bracket moulded into the back cover.
      Chiedi a FixBot
      Aggiungi Commento
    6. Kobo Clara HD Repairs, Storage: passo 6, immagine 1 di 2 Kobo Clara HD Repairs, Storage: passo 6, immagine 2 di 2
      • All the storage is on a microSD card hidden inside the device.
      • Swap it out at your own risk.
      Chiedi a FixBot
      Aggiungi Commento
    7. Kobo Clara HD Repairs, Logic board: passo 7, immagine 1 di 2 Kobo Clara HD Repairs, Logic board: passo 7, immagine 2 di 2
      • Use a Phillips #00 screwdriver to remove the 4 screws securing the logic board.
      • Lift the logic board out from the top of the device.
      • There is a black sheet of plastic that sits under the logic board.
      Chiedi a FixBot
      Aggiungi Commento
    8. Kobo Clara HD Repairs: passo 8, immagine 1 di 2 Kobo Clara HD Repairs: passo 8, immagine 2 di 2
      • To reassemble your device, follow these steps in reverse order.
      • Pro tip: when closing the plastic housing, squeeze it shut close to the edges to avoid putting too much pressure on the display.
      Chiedi a FixBot
      Aggiungi Commento
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Sparky
Membro da: 03/15/26
1.535 Reputazione
10 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 13
Ultimi 7 giorni: 103
Ultimi 30 giorni: 439
Tutti i Tempi: 1,406
