Salta al contenuto principale
Knot Thread to the Fabric (2 Ways)
Cosa ti serve
  1. Knot Thread to the Fabric (2 Ways), Secure knot type 1: passo 1, immagine 1 di 3 Knot Thread to the Fabric (2 Ways), Secure knot type 1: passo 1, immagine 2 di 3 Knot Thread to the Fabric (2 Ways), Secure knot type 1: passo 1, immagine 3 di 3
    • On the backside of the fabric, make a very small stitch.
    • Pull the thread through, leaving a short tail of approximately 1/2 inch (~13 mm) to 1 inch (~25 mm).
    • Make another small stitch in the same area. Leave the needle piercing the fabric without pulling it all the way through.
  2. Knot Thread to the Fabric (2 Ways): passo 2, immagine 1 di 3 Knot Thread to the Fabric (2 Ways): passo 2, immagine 2 di 3 Knot Thread to the Fabric (2 Ways): passo 2, immagine 3 di 3
    • Take the thread that's emerging from the stitch and wrap it around the needle.
    • Wrap the thread around the needle a second time.
    • Push the wrapped threads down towards the base of the needle where it's emerging from the fabric.
  3. Knot Thread to the Fabric (2 Ways): passo 3, immagine 1 di 1
    • Pull the needle through the loops and pull the thread tight. The knot will lay flush with the fabric.
    • This video shows how to start a stitch with secure knot type 1.
    • This video shows how to end a stitch with secure knot type 1.
  4. Knot Thread to the Fabric (2 Ways), Secure knot type 2: passo 6, immagine 1 di 2 Knot Thread to the Fabric (2 Ways), Secure knot type 2: passo 6, immagine 2 di 2
  5. Knot Thread to the Fabric (2 Ways): passo 7, immagine 1 di 2 Knot Thread to the Fabric (2 Ways): passo 7, immagine 2 di 2
    • Make another small stitch in the same area, across the first stitch.
    • Pull the thread through but don't pull it tight, leaving a small loop.
  6. Knot Thread to the Fabric (2 Ways): passo 8, immagine 1 di 2 Knot Thread to the Fabric (2 Ways): passo 8, immagine 2 di 2
    • Thread the needle through the loop that was created in the previous step.
    • Gently pull the needle through the loop without pulling the thread tight, keeping the thread loop intact.
  7. Knot Thread to the Fabric (2 Ways): passo 9, immagine 1 di 2 Knot Thread to the Fabric (2 Ways): passo 9, immagine 2 di 2
    • Thread the needle through the loop again in the same direction as the previous step.
    • Pull the thread tight to secure the knot. The knot will lay flush against the fabric.
    • This video shows how to start a stitch with secure knot type 2.
    • This video shows how to end a stitch with secure knot type 2.
Linea Traguardo
Clara Redwood
Membro da: 11/12/24
2.544 Reputazione
18 Guide realizzate
Patagonia Membro di Patagonia
Community
17 Membri
168 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 110
Tutti i Tempi: 552
