Salta al contenuto principale
KitchenAid KHM512ER Eject Button Spring Replacement
Cosa ti serve
  1. KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: passo 1, immagine 1 di 2 KitchenAid KHM512ER Eject Button Spring Replacement, Eject Button Spring: passo 1, immagine 2 di 2
    • Insert the back of a plastic opening tool into one of the beater holes.
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
    Chiedi a FixBot
    Aggiungi Commento
  2. KitchenAid KHM512ER Eject Button Spring Replacement: passo 2, immagine 1 di 3 KitchenAid KHM512ER Eject Button Spring Replacement: passo 2, immagine 2 di 3 KitchenAid KHM512ER Eject Button Spring Replacement: passo 2, immagine 3 di 3
    • Use a plastic opening tool to remove the speed knob.
    • Use a plastic opening tool to remove the long plastic piece
    • Use a plastic opening tool to remove the speed switch.
    Chiedi a FixBot
    Aggiungi Commento
  3. KitchenAid KHM512ER Eject Button Spring Replacement: passo 3, immagine 1 di 2 KitchenAid KHM512ER Eject Button Spring Replacement: passo 3, immagine 2 di 2
    • Use a Phillips 2 screwdriver to remove the two 20.0mm screws holding the bottom plastic piece on.
    • Your screwdriver may not be long or narrow enough to reach the screws in these holes. If that's the case, use another screwdriver.
    • Remove the bottom plastic piece using a plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  4. KitchenAid KHM512ER Eject Button Spring Replacement: passo 4, immagine 1 di 3 KitchenAid KHM512ER Eject Button Spring Replacement: passo 4, immagine 2 di 3 KitchenAid KHM512ER Eject Button Spring Replacement: passo 4, immagine 3 di 3
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
    • Use your hands to hold the eject button from one side while using the other hand to remove the circuit board.
    Chiedi a FixBot
    Aggiungi Commento
  5. KitchenAid KHM512ER Eject Button Spring Replacement: passo 5, immagine 1 di 2 KitchenAid KHM512ER Eject Button Spring Replacement: passo 5, immagine 2 di 2
    • Remove the eject button by pulling it from the inside of the mixer.
    • Hold the eject button firmly while pulling out the spring.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Yuriy Zaynulin
Membro da: 02/10/16
191 Reputazione
Una guida realizzata
USF Tampa, Team 2-3, Sullivan Spring 2016 Membro di USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Membri
9 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 37
Tutti i Tempi: 2,085
