Salta al contenuto principale
Keurig K55 Lid Spring Replacement
Cosa ti serve
    1. Keurig K55 Lid Spring Replacement, Secondary Water Pump: passo 1, immagine 1 di 3 Keurig K55 Lid Spring Replacement, Secondary Water Pump: passo 1, immagine 2 di 3 Keurig K55 Lid Spring Replacement, Secondary Water Pump: passo 1, immagine 3 di 3
      • Lift the silver handle up.
      • Locate the screw and washer holding the handle in place on each side.
      • Remove both 13mm screws and washers using a Phillips #0 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    2. Keurig K55 Lid Spring Replacement: passo 2, immagine 1 di 2 Keurig K55 Lid Spring Replacement: passo 2, immagine 2 di 2
      • Grab the handle and pull it upward and toward the rear of the device.
      • Lift the lid to the fully open position.
      • Remove the two 11mm Phillips screws located on the upper part of the device.
      • Be careful removing the screws; the needle here may be sharp.
      Chiedi a FixBot
      Aggiungi Commento
    3. Keurig K55 Lid Spring Replacement: passo 3, immagine 1 di 3 Keurig K55 Lid Spring Replacement: passo 3, immagine 2 di 3 Keurig K55 Lid Spring Replacement: passo 3, immagine 3 di 3
      • Lower the lid to just before its closing position.
      • Grab the black top cover with the Keurig logo and gently push back toward the rear of the device to release it.
      • Gently pull the top cover upward and toward the front of the device to remove it.
      Chiedi a FixBot
      Aggiungi Commento
    4. Keurig K55 Lid Spring Replacement: passo 4, immagine 1 di 3 Keurig K55 Lid Spring Replacement: passo 4, immagine 2 di 3 Keurig K55 Lid Spring Replacement: passo 4, immagine 3 di 3
      • Remove the two 11mm Phillips head screws securing the water pump.
      • Grab the secondary water pump firmly and pull one of the plastic water lines off of the pump.
      • Pull the other line from the water pump.
      Chiedi a FixBot
      Aggiungi Commento
    1. Keurig K55 Lid Spring Replacement, Lid Spring: passo 5, immagine 1 di 2 Keurig K55 Lid Spring Replacement, Lid Spring: passo 5, immagine 2 di 2
      • Pull the spring off the front hook using two fingers.
      • The spring has a lot of tension, so grip the spring end tightly.
      Chiedi a FixBot
      Aggiungi Commento
    2. Keurig K55 Lid Spring Replacement: passo 6, immagine 1 di 2 Keurig K55 Lid Spring Replacement: passo 6, immagine 2 di 2
      • Pull the spring off the other hook.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team S1-G3, Livingston Winter 2018 Membro di Cal Poly, Team S1-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G3
4 Membri
15 guide realizzate
2Commenti sulla guida
What is the small plastic/rubber angled water line part that the front part of the water pump valve is inserted into ?
Joe K - Rispondi Condividi
Well i might have described it as a water pump in my above message, but from what I've read on here it is a check valve, so what is the rubber/plastic small angled water line part that the front of the check valve is inserted into !
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 10
Ultimi 30 giorni: 54
Tutti i Tempi: 2,591
