Introduzione
Use this guide to replace the ice maker in your older Kenmore side-by-side refrigerator.
The ice maker produces ice automatically until the ice storage bin is full.
If the ice maker fails, no ice may be produced, the ice maker inlet may freeze and cause leaks, or the ice may not be properly harvested. In these cases, the ice maker will likely need replacement.
This guide was created using a Kenmore model 106.9555782 side-by-side refrigerator
Cosa ti serve
Use a 1/4" nutdriver to loosen or remove the screws securing the ice maker to the side of the freezer compartment.
Lift the ice maker upward and tilt to the right to free it from the screws.
Reposition the ice maker so that it is supported on the shelf below and you have access to the electrical connector.
Grasp the connector (red arrow) and lift the retaining tab.
Pull the connector out of the socket (red box).
1Commento della guida
mine doesn't have a pug in the wires go into the left side and appears to be a rubber Plug. How do I disconnect?
