Introduzione
The battery will be replaced by dismantling the device, disconnecting the current battery and connecting a new battery.
Cosa ti serve
Insert the plastic opening tool underneath the mesh top.
Pry the cover open.
Strumento utilizzato in questo passaggio:Halberd Spudger$2.99
Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
Pull the speaker up and out.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Expose the motherboard and battery and place in a position that will be easy to access and work with.
Use tweezers to remove the battery's wire from the motherboard at the connection point.
Pull the battery from the motherboard.
