Salta al contenuto principale
JBL Wave Beam Case Disassembly
Cosa ti serve
    1. JBL Wave Beam Case Disassembly, Heat up the case: passo 1, immagine 1 di 1
      • Open up your case and remove the earbuds. Prepare a heat gun at around 150℃, and gently heat up the front part of the case, around where the LED is.
      Chiedi a FixBot
      Aggiungi Commento
    2. JBL Wave Beam Case Disassembly, Insert a plastic pick: passo 2, immagine 1 di 2 JBL Wave Beam Case Disassembly, Insert a plastic pick: passo 2, immagine 2 di 2
      • Now try to insert an opening pick into the seam as shown. If you can't get it in, try heating the case more or using a different pick.
      • Slide the pick around the edge of the case until it reaches the back, next to the hinge part. You can apply more heat here if this is too difficult.
      • Repeat with a second opening pick, going round the other side. The second image shows what your case should now look like.
      Chiedi a FixBot
      Aggiungi Commento
    3. JBL Wave Beam Case Disassembly, Lift out the internals: passo 3, immagine 1 di 1
      • Use a plastic tool to lift up the internals as shown
      • If this is too difficult, you might want to use a third pick, and pry around the area under the LED.
      Chiedi a FixBot
      Aggiungi Commento
    4. JBL Wave Beam Case Disassembly, Remove the electronics: passo 4, immagine 1 di 2 JBL Wave Beam Case Disassembly, Remove the electronics: passo 4, immagine 2 di 2
      • You should now have removed the outer case. Remove the two Phillips #0 screws next to the exposed USB port.
      • Pull the motherboard directly upwards. Be gentle here, as it is still connected to the glued-down battery
      • Use a plastic tool to pry out the battery, it is attached to the case with a sticky pad. If you have isopropyl alcohol, apply some underneath the battery to loosen the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
    5. JBL Wave Beam Case Disassembly, Desolder the battery: passo 5, immagine 1 di 1
      • The battery is connected to the motherboard with either 3 or 2 solder pads. Use a soldering iron and flux to remove all of them, being careful not to cause any shorts.
      Chiedi a FixBot
      Aggiungi Commento
      • Solder the black and red wires of your new battery to GND and BATT on the motherboard, respectively. If there is a third wire (temperature sensor) solder it to the NTC pad.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 6
Ultimi 7 giorni: 81
Ultimi 30 giorni: 383
Tutti i Tempi: 2,730
