Salta al contenuto principale
Ivation IVWPDC20Y Flash Bulb Replacement
Cosa ti serve
    1. Ivation IVWPDC20Y Flash Bulb Replacement, Flash Bulb: passo 1, immagine 1 di 1
      • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
      Chiedi a FixBot
      Aggiungi Commento
    2. Ivation IVWPDC20Y Flash Bulb Replacement: passo 2, immagine 1 di 1
      • Apply a plastic opening tool to each of the corners and gently remove the casing
      • The front casing is held down by adhesive and may require additional work to remove
      • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
      Chiedi a FixBot
      Aggiungi Commento
    3. Ivation IVWPDC20Y Flash Bulb Replacement: passo 3, immagine 1 di 1
      • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
      Chiedi a FixBot
      Aggiungi Commento
    4. Ivation IVWPDC20Y Flash Bulb Replacement: passo 4, immagine 1 di 1
      • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
      • These screws are very small and easy to strip so apply consistent pressure when removing them
      Chiedi a FixBot
      Aggiungi Commento
    5. Ivation IVWPDC20Y Flash Bulb Replacement: passo 5, immagine 1 di 1
      • Pry off back outer casing using the black spudger or the blue prying tools
      Chiedi a FixBot
      Aggiungi Commento
    6. Ivation IVWPDC20Y Flash Bulb Replacement: passo 6, immagine 1 di 1
      • Carefully remove the screen from the silver casing using a prying tool or the black spudger
      • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
      Chiedi a FixBot
      Aggiungi Commento
    7. Ivation IVWPDC20Y Flash Bulb Replacement: passo 7, immagine 1 di 1
      • Gently push out the pins holding the orange tape down using the pointy end of the spudger
      • Screen and orange tape should slip out as a whole
      Chiedi a FixBot
      Aggiungi Commento
    8. Ivation IVWPDC20Y Flash Bulb Replacement: passo 8, immagine 1 di 1
      • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
      Chiedi a FixBot
      Aggiungi Commento
    9. Ivation IVWPDC20Y Flash Bulb Replacement: passo 9, immagine 1 di 1
      • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
      Chiedi a FixBot
      Aggiungi Commento
    10. Ivation IVWPDC20Y Flash Bulb Replacement: passo 10, immagine 1 di 1
      • Gently lift the corner of the motherboard out
      • Everything should come out as one component free of the casing
      Chiedi a FixBot
      Aggiungi Commento
    11. Ivation IVWPDC20Y Flash Bulb Replacement: passo 11, immagine 1 di 1
      • Remove the soldering on the three wires holding the flash bulb
      • The wires are different colors: red, white, and black
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
USF Tampa, Team 6-6, Eyestone Spring 2016 Membro di USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 24
Tutti i Tempi: 521
