Salta al contenuto principale
Instax Mini 90 Battery Replacement
Cosa ti serve
  1. Instax Mini 90 Battery Replacement, Battery: passo 1, immagine 1 di 2 Instax Mini 90 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • The battery compartment can be found on the backside of the camera. Pinpoint this compartment and focus on the right edge of the compartment gate to find the opening latch.
    Chiedi a FixBot
    Aggiungi Commento
  2. Instax Mini 90 Battery Replacement: passo 2, immagine 1 di 2 Instax Mini 90 Battery Replacement: passo 2, immagine 2 di 2
    • Pinch the latch in towards the battery compartment gate. This will release the gate and allow it to open.
    • Completely open the gate and remove from camera for ease of insertion of the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. Instax Mini 90 Battery Replacement: passo 3, immagine 1 di 2 Instax Mini 90 Battery Replacement: passo 3, immagine 2 di 2
    • Insert the battery into the battery compartment by following the diagram printed on the camera.
    • Be sure to connect the correct terminals of the battery to the camera.
    • Reattach battery compartment door to the camera and close firmly. A clicking sound will result when compartment door has been closed fully.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
1Commento della guida
Also use a #0 screwdriver, not a 000#. The 000 may work but the 0 fits better
John Doe - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 9
Ultimi 30 giorni: 59
Tutti i Tempi: 14,332
