Salta al contenuto principale
Insignia Flex 8 Screen Replacement
Cosa ti serve
    1. Insignia Flex 8 Screen Replacement, Circuit Board: passo 1, immagine 1 di 1
      • Turn off the power to your tablet to avoid injury.
      • Position the tablet so that the screen is face down and the power button is located in the upper left hand corner.
      • Hold down the power button for five seconds until the tablet powers down.
      Chiedi a FixBot
      Aggiungi Commento
    2. Insignia Flex 8 Screen Replacement: passo 2, immagine 1 di 2 Insignia Flex 8 Screen Replacement: passo 2, immagine 2 di 2
      • Remove the back casing from the screen by sliding a credit card or a similarly thin but firm object in between the casing and the screen.
      • You may need to use a spudger to initially create separation between the screen and the casing.
      • Run this object around the perimeter of the tablet until there is separation between the casing and the screen.
      • Remove the back casing and set aside.
      Chiedi a FixBot
      Aggiungi Commento
    3. Insignia Flex 8 Screen Replacement: passo 3, immagine 1 di 2 Insignia Flex 8 Screen Replacement: passo 3, immagine 2 di 2
      • Peel tape off of ribbon connectors. Starting at the power button, work clockwise around the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    4. Insignia Flex 8 Screen Replacement: passo 4, immagine 1 di 3 Insignia Flex 8 Screen Replacement: passo 4, immagine 2 di 3 Insignia Flex 8 Screen Replacement: passo 4, immagine 3 di 3
      • To remove the camera ribbon cable, lift the flap using a spudger.
      • Pull the ribbon directly back to release it.
      Chiedi a FixBot
      Aggiungi Commento
    5. Insignia Flex 8 Screen Replacement: passo 5, immagine 1 di 3 Insignia Flex 8 Screen Replacement: passo 5, immagine 2 di 3 Insignia Flex 8 Screen Replacement: passo 5, immagine 3 di 3
      • Remove the second ribbon cable by prying up the black flap using a spudger.
      • Pull the ribbon cable horizontally directly away from the battery.
      Chiedi a FixBot
      Aggiungi Commento
    6. Insignia Flex 8 Screen Replacement: passo 6, immagine 1 di 3 Insignia Flex 8 Screen Replacement: passo 6, immagine 2 di 3 Insignia Flex 8 Screen Replacement: passo 6, immagine 3 di 3
      • Remove the final ribbon cable by pulling back the two black tabs on either side of the ribbon cable.
      • Pull the ribbon horizontally directly away from the battery.
      Chiedi a FixBot
      Aggiungi Commento
    7. Insignia Flex 8 Screen Replacement: passo 7, immagine 1 di 2 Insignia Flex 8 Screen Replacement: passo 7, immagine 2 di 2
      • Unscrew the thirteen 4.75mm screws around the perimeter of the tablet using a PH 00 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    8. Insignia Flex 8 Screen Replacement: passo 8, immagine 1 di 2 Insignia Flex 8 Screen Replacement: passo 8, immagine 2 di 2
      • Unscrew the four 3.75mm screws and plastic washers using a PH 00 screwdriver.
      • Lift up the circuit board.
      Chiedi a FixBot
      Aggiungi Commento
    9. Insignia Flex 8 Screen Replacement: passo 9, immagine 1 di 1
      • Unscrew the final two screws that were underneath the circuit board.
      • These screws are near the charging port and USB adapter.
      • These screws are also 3.75mm and can be interchanged with the second set of screws only.
      Chiedi a FixBot
      Aggiungi Commento
    10. Insignia Flex 8 Screen Replacement: passo 10, immagine 1 di 1
      • Lift the circuit board and black internal mounting piece away from the screen.
      • Set the circuit board aside.
      • Be careful of the soldered antenna as you separate the pieces.
      • Be careful of the soldered ribbon that is connected to the power source. This ribbon is fragile.
      Chiedi a FixBot
      Aggiungi Commento
    1. Insignia Flex 8 Screen Replacement, Screen: passo 11, immagine 1 di 1
      • Slide the spudger in between the silver screen and the black border
      Chiedi a FixBot
      Aggiungi Commento
    2. Insignia Flex 8 Screen Replacement: passo 12, immagine 1 di 1
      • Pry up the LCD display and lift it away from the plastic screen.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 40
Tutti i Tempi: 8,662
