Salta al contenuto principale
Infant Optics DXR-8 Monitor Motherboard Replacement
Cosa ti serve
  1. Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: passo 1, immagine 1 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: passo 1, immagine 2 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Internal Monitor Components: passo 1, immagine 3 di 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Monitor Motherboard Replacement: passo 2, immagine 1 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement: passo 2, immagine 2 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Monitor Motherboard Replacement: passo 3, immagine 1 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement: passo 3, immagine 2 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement: passo 3, immagine 3 di 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: passo 4, immagine 1 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: passo 4, immagine 2 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Screen: passo 4, immagine 3 di 3
    • Using a plastic opening tool, disconnect the ribbon cable connector.
    • Gently separate the ribbon cable from the motherboard.
  5. Infant Optics DXR-8 Monitor Motherboard Replacement: passo 5, immagine 1 di 2 Infant Optics DXR-8 Monitor Motherboard Replacement: passo 5, immagine 2 di 2
    • Using a Phillips #000 screwdriver, remove the four 4mm screws around the edge of the motherboard.
    • Flip the motherboard away from the front case to reveal the screen on the other side.
  6. Infant Optics DXR-8 Monitor Motherboard Replacement: passo 6, immagine 1 di 1
    • Using a plastic opening tool, carefully pry the top retaining frame off of the screen. Start in one corner and work around the bottom of the frame.
  7. Infant Optics DXR-8 Monitor Motherboard Replacement: passo 7, immagine 1 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement: passo 7, immagine 2 di 3 Infant Optics DXR-8 Monitor Motherboard Replacement: passo 7, immagine 3 di 3
    • Using a plastic opening pick, carefully pry a corner of the screen away from the motherboard.
    • Lift the screen off of the motherboard.
  8. Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: passo 8, immagine 1 di 2 Infant Optics DXR-8 Monitor Motherboard Replacement, Monitor Motherboard: passo 8, immagine 2 di 2
    • Flip the motherboard away from the case.
    • Using a soldering iron and desoldering braid, desolder the antenna from the motherboard.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
Conclusione
2 Commenti
Can you do one for the DXR-8 Pro monitor? Mine randomly stoped turning on and I want to see if I can open it up and try to fix it.
Andfel - Replica
Can you please tell me where to buy a replacement motherboard??
Ilya Nechay - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,361
