Introduzione
Replace the lens if you are experiencing a lack of an image when the projector is on.
You will need a replacement lens as well as a clean, micro fabric cloth in case the replacement lens needs to be cleaned.
Cosa ti serve
Flip the projector on its back.
Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
Using the Phillips #1 screwdriver, remove the (3) three 1cm black screws on the face of the lens.
Gently pull out the lens.
To reassemble the device, follow these instructions in reverse order.
