Salta al contenuto principale
InFocus Screenplay 4805 Lamp Rebuild
Cosa ti serve
  1. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 1, immagine 1 di 2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 1, immagine 2 di 2
    • This guide assumes tht you have removed the lamp unit from the projector. If you have not, refer to this guide first: InFocus Screenplay 4805 Lamp Replacement
    • Slide the bulb housing out of the projector.
    • Use the Phillips #1 screwdriver to remove the three 1 cm gold screws on the bulb housing.
    Chiedi a FixBot
    Aggiungi Commento
  2. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 2, immagine 1 di 2 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 2, immagine 2 di 2
    • This step is only required when rebuilding the old lamp with a replacement bulb.
    • Gently pull the top of the bulb housing off.
    • Lift up the middle of the bulb housing to remove it.
    • Be careful of loose parts, such as the metal housing and the glass focusing lens.
    Chiedi a FixBot
    Aggiungi Commento
  3. InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 3, immagine 1 di 3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 3, immagine 2 di 3 InFocus Screenplay 4805 Lamp Rebuild, **REBUILD ONLY** Housing disassembly: passo 3, immagine 3 di 3
    • Unhook the spring from the bulb housing.
    • Gently remove the bulb.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble the device, follow these instructions in reverse order.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 13
Tutti i Tempi: 150
