Salta al contenuto principale
InFocus LP540 Projector Speakers Replacement
Cosa ti serve
    1. InFocus LP540 Projector Speakers Replacement, Speakers: passo 1, immagine 1 di 3 InFocus LP540 Projector Speakers Replacement, Speakers: passo 1, immagine 2 di 3 InFocus LP540 Projector Speakers Replacement, Speakers: passo 1, immagine 3 di 3
      • Flip the projector right-side up and turn it so the backports face you.
      • Remove the 7mm metallic hex screws using the screwdriver.
      • Remove the two black 10mm screws using the T10 Torx screwdriver head. The screws are located at the center of the back panel.
      Chiedi a FixBot
      Aggiungi Commento
    2. InFocus LP540 Projector Speakers Replacement: passo 2, immagine 1 di 2 InFocus LP540 Projector Speakers Replacement: passo 2, immagine 2 di 2
      • Remove the two 77mm screws that are located nearest to the back panel ports using a T10 Torx screwdriver.
      • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver.
      • Flip the projector back over.
      • Cautiously lift the main lid to avoid ripping the electrical strips.
      Chiedi a FixBot
      Aggiungi Commento
    3. InFocus LP540 Projector Speakers Replacement: passo 3, immagine 1 di 2 InFocus LP540 Projector Speakers Replacement: passo 3, immagine 2 di 2
      • Unplug the speaker wire from the circuit board by squeezing the sides and pulling.
      • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
      Chiedi a FixBot
      Aggiungi Commento
    4. InFocus LP540 Projector Speakers Replacement: passo 4, immagine 1 di 3 InFocus LP540 Projector Speakers Replacement: passo 4, immagine 2 di 3 InFocus LP540 Projector Speakers Replacement: passo 4, immagine 3 di 3
      • Place the top shell of the projector down.
      • Remove the speaker wires from the white tabs.
      • Use a Phillips #0 screwdriver to remove the four 5.5 mm screws.
      • Carefully lift the speakers to remove them.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Reassembly: Close the speaker compartment and replace the light cover. Screw it back into place to secure all parts.
Cal Poly, Team 13-17, Regan Winter 2014 Membro di Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Membri
15 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 904
