Salta al contenuto principale
InFocus IN3104 Lamp Replacement
Cosa ti serve
  1. InFocus IN3104 Lamp Replacement, Top Cover: passo 1, immagine 1 di 3 InFocus IN3104 Lamp Replacement, Top Cover: passo 1, immagine 2 di 3 InFocus IN3104 Lamp Replacement, Top Cover: passo 1, immagine 3 di 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
    Chiedi a FixBot
    Aggiungi Commento
  2. InFocus IN3104 Lamp Replacement: passo 2, immagine 1 di 3 InFocus IN3104 Lamp Replacement: passo 2, immagine 2 di 3 InFocus IN3104 Lamp Replacement: passo 2, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  3. InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, immagine 1 di 2 InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: passo 3, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. InFocus IN3104 Lamp Replacement: passo 4, immagine 1 di 3 InFocus IN3104 Lamp Replacement: passo 4, immagine 2 di 3 InFocus IN3104 Lamp Replacement: passo 4, immagine 3 di 3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
    Chiedi a FixBot
    Aggiungi Commento
  5. InFocus IN3104 Lamp Replacement, Lamp: passo 5, immagine 1 di 3 InFocus IN3104 Lamp Replacement, Lamp: passo 5, immagine 2 di 3 InFocus IN3104 Lamp Replacement, Lamp: passo 5, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the four 6 mm screws.
    • You may need to use a flexible extender to help remove the screws easily.
    Chiedi a FixBot
    Aggiungi Commento
  6. InFocus IN3104 Lamp Replacement: passo 6, immagine 1 di 3 InFocus IN3104 Lamp Replacement: passo 6, immagine 2 di 3 InFocus IN3104 Lamp Replacement: passo 6, immagine 3 di 3
    • Remove the lamp power cable situated beside the lamp by pulling it straight out.
    • Remove the lamp by pulling it straight out from the device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 8
Ultimi 30 giorni: 45
Tutti i Tempi: 1,058
