Salta al contenuto principale
IBM Thinkpad T60 LCD Screen Replacement
Cosa ti serve
    1. IBM Thinkpad T60 LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
      • Turn the computer over to see the small tab on the battery located near the top of the Thinkpad.
      • Use your finger to slide the tab to the right to unlock the battery.
      Chiedi a FixBot
      Aggiungi Commento
    2. IBM Thinkpad T60 LCD Screen Replacement: passo 2, immagine 1 di 2 IBM Thinkpad T60 LCD Screen Replacement: passo 2, immagine 2 di 2
      • Once the tab is in the unlocked position (far right), pull the battery outwards away from the Thinkpad.
      • The battery is now disconnected.
      Chiedi a FixBot
      Aggiungi Commento
    1. IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: passo 3, immagine 1 di 3 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: passo 3, immagine 2 di 3 IBM Thinkpad T60 LCD Screen Replacement, LCD Screen: passo 3, immagine 3 di 3
      • Open the laptop so that the screen is facing you.
      • Use a plastic opening tool to pry off the eight plastic screw covers around the display.
      • Note that there are screw covers on the sides (two on the left and one on the right).
      Chiedi a FixBot
      Aggiungi Commento
    2. IBM Thinkpad T60 LCD Screen Replacement: passo 4, immagine 1 di 1
      • Use a #0 Phillips screwdriver to remove the eight 3.25 mm screws uncapped from the previous step.
      Chiedi a FixBot
      Aggiungi Commento
    3. IBM Thinkpad T60 LCD Screen Replacement: passo 5, immagine 1 di 2 IBM Thinkpad T60 LCD Screen Replacement: passo 5, immagine 2 di 2
      • Carefully pry the plastic border away from the screen using the plastic opening tool.
      • Note that this step requires some force. There are plastic clips that help hold the border in place so do not worry about snapping sounds.
      Chiedi a FixBot
      Aggiungi Commento
    4. IBM Thinkpad T60 LCD Screen Replacement: passo 6, immagine 1 di 1
      • Use your fingers to pry the screen out of its housing far enough to gain access to the ribbon cables and small screws holding the screen in place.
      Chiedi a FixBot
      Aggiungi Commento
    5. IBM Thinkpad T60 LCD Screen Replacement: passo 7, immagine 1 di 1
      • At the top of the screen, detach the small white clip by pulling it towards you with your finger.
      Chiedi a FixBot
      Aggiungi Commento
    6. IBM Thinkpad T60 LCD Screen Replacement: passo 8, immagine 1 di 2 IBM Thinkpad T60 LCD Screen Replacement: passo 8, immagine 2 di 2
      • Using a #0 Phillips screwdriver, remove the 4 mm screw.
      Chiedi a FixBot
      Aggiungi Commento
    7. IBM Thinkpad T60 LCD Screen Replacement: passo 9, immagine 1 di 2 IBM Thinkpad T60 LCD Screen Replacement: passo 9, immagine 2 di 2
      • Using a #0 Phillips screwdriver, remove the four 3.25 mm screws
      • The other two screws are in the same position on the opposite side of the display.
      Chiedi a FixBot
      Aggiungi Commento
    8. IBM Thinkpad T60 LCD Screen Replacement: passo 10, immagine 1 di 2 IBM Thinkpad T60 LCD Screen Replacement: passo 10, immagine 2 di 2
      • The screen should be free to move now. Let the display rest on the keyboard with the screen facing down.
      • Peel the tape off to expose the LCD connection.
      Chiedi a FixBot
      Aggiungi Commento
    9. IBM Thinkpad T60 LCD Screen Replacement: passo 11, immagine 1 di 2 IBM Thinkpad T60 LCD Screen Replacement: passo 11, immagine 2 di 2
      • Turn the inverter over to expose the white clip.
      • Squeeze and pull the wires with your fingers to detach the white clip.
      Chiedi a FixBot
      Aggiungi Commento
    10. IBM Thinkpad T60 LCD Screen Replacement: passo 12, immagine 1 di 1
      • Disconnect the video cable by pulling the grey flat wire. Now the screen is completely separate from the ThinkPad.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team 7-9, Maness Winter 2013 Membro di Cal Poly, Team 7-9, Maness Winter 2013
CPSU-MANESS-W13S7G9
4 Membri
32 guide realizzate
1Commento della guida
Thanks for the info! ☼
Stck Flw - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 16
Ultimi 30 giorni: 79
Tutti i Tempi: 13,858
