Salta al contenuto principale
IBM ThinkPad R40 Keyboard Keys Replacement
Cosa ti serve
  1. IBM ThinkPad R40 Keyboard Keys Replacement, Disconnection: passo 1, immagine 1 di 1
    • Make sure your laptop is off and disconnected from the power source to ensure safety for yourself.
    Chiedi a FixBot
    Aggiungi Commento
  2. IBM ThinkPad R40 Keyboard Keys Replacement, Replacement: passo 2, immagine 1 di 1
    Strumento utilizzato in questo passaggio:
    • Locate the key that needs replacing. Use tweezers to slowly pull the key off the keyboard. Doing this will expose the underside of the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  3. IBM ThinkPad R40 Keyboard Keys Replacement, Set aside: passo 3, immagine 1 di 1
    • Step 3: Set the old key aside and have the new key ready to be inserted onto the computer. The key has three parts, which you can see here.
    Chiedi a FixBot
    Aggiungi Commento
  4. IBM ThinkPad R40 Keyboard Keys Replacement, Moving inside: passo 4, immagine 1 di 1
    • The new key will have an empty slot where they key used to be. It contains a small rubber spring. After the rubber spring is inserted take the new key and line it up according to the color springs on the backside of the key along with the keyboard.
    Chiedi a FixBot
    Aggiungi Commento
  5. IBM ThinkPad R40 Keyboard Keys Replacement, Lining up: passo 5, immagine 1 di 1
    • After lining the key up, the black and white pieces will line up.
    Chiedi a FixBot
    Aggiungi Commento
  6. IBM ThinkPad R40 Keyboard Keys Replacement, Finishing up: passo 6, immagine 1 di 1
    • Step 6: The key should not be firmly locked into place and functioning normally.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Erin
Membro da: 09/08/11
231 Reputazione
2 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 10
Ultimi 30 giorni: 44
Tutti i Tempi: 5,289
