Salta al contenuto principale
IBM ThinkPad A30 Fan Replacement
Cosa ti serve
  1. IBM ThinkPad A30 Fan Replacement, Battery: passo 1, immagine 1 di 2 IBM ThinkPad A30 Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  2. IBM ThinkPad A30 Fan Replacement, Upper Case: passo 2, immagine 1 di 1
    • Make sure the laptop is upside down and oriented in the direction shown.
    • Remove the six 16.7mm screws inside the circled holes.
    Chiedi a FixBot
    Aggiungi Commento
  3. IBM ThinkPad A30 Fan Replacement: passo 3, immagine 1 di 1
    • Rotate the ThinkPad so that the hard drive bay is facing you.
    • Remove the black cover to reveal a 14.8mm screw.
    • Remove the uncovered screw with a Phillips #0 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  4. IBM ThinkPad A30 Fan Replacement: passo 4, immagine 1 di 2 IBM ThinkPad A30 Fan Replacement: passo 4, immagine 2 di 2
    • Flip the ThinkPad over and open the LCD panel.
    • Pry apart the keyboard with a plastic opening tool or with your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  5. IBM ThinkPad A30 Fan Replacement: passo 5, immagine 1 di 3 IBM ThinkPad A30 Fan Replacement: passo 5, immagine 2 di 3 IBM ThinkPad A30 Fan Replacement: passo 5, immagine 3 di 3
    • Be careful not to pull out the keyboard carelessly; there is a connector underneath it!
    • Lift the front end of the keyboard as shown.
    • Using your fingers, remove the black film cover.
    Chiedi a FixBot
    Aggiungi Commento
  6. IBM ThinkPad A30 Fan Replacement: passo 6, immagine 1 di 3 IBM ThinkPad A30 Fan Replacement: passo 6, immagine 2 di 3 IBM ThinkPad A30 Fan Replacement: passo 6, immagine 3 di 3
    • Locate the connector attached to the motherboard.
    • Disconnect the ribbon cable by removing the connector.
    Chiedi a FixBot
    Aggiungi Commento
  7. IBM ThinkPad A30 Fan Replacement: passo 7, immagine 1 di 2 IBM ThinkPad A30 Fan Replacement: passo 7, immagine 2 di 2
    • Lift and remove the keyboard.
    • Remove the two 5.6mm screws.
    • Remove the 16.7mm screw.
    Chiedi a FixBot
    Aggiungi Commento
  8. IBM ThinkPad A30 Fan Replacement: passo 8, immagine 1 di 3 IBM ThinkPad A30 Fan Replacement: passo 8, immagine 2 di 3 IBM ThinkPad A30 Fan Replacement: passo 8, immagine 3 di 3
    • You will need to use a little force. Be wary of the tabs.
    • Pry off the upper case with your hands.
    Chiedi a FixBot
    Aggiungi Commento
  9. IBM ThinkPad A30 Fan Replacement, Display Assembly: passo 9, immagine 1 di 1
    • Remove the 5.6mm screw that holds the LCD to the upper case.
    Chiedi a FixBot
    Aggiungi Commento
  10. IBM ThinkPad A30 Fan Replacement: passo 10, immagine 1 di 3 IBM ThinkPad A30 Fan Replacement: passo 10, immagine 2 di 3 IBM ThinkPad A30 Fan Replacement: passo 10, immagine 3 di 3
    • Remove the 5.6mm screw on the left side of the three-pronged connector.
    • Remove the other two 16.7mm screws.
    • Lift and remove connector.
    Chiedi a FixBot
    Aggiungi Commento
  11. IBM ThinkPad A30 Fan Replacement: passo 11, immagine 1 di 2 IBM ThinkPad A30 Fan Replacement: passo 11, immagine 2 di 2
    • Pull out the white tab connecting the LCD to the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  12. IBM ThinkPad A30 Fan Replacement: passo 12, immagine 1 di 2 IBM ThinkPad A30 Fan Replacement: passo 12, immagine 2 di 2
    • Turn the laptop so that the back is facing you.
    • Remove the four 5.6mm long screws.
    Chiedi a FixBot
    Aggiungi Commento
  13. IBM ThinkPad A30 Fan Replacement: passo 13, immagine 1 di 3 IBM ThinkPad A30 Fan Replacement: passo 13, immagine 2 di 3 IBM ThinkPad A30 Fan Replacement: passo 13, immagine 3 di 3
    • Place the laptop so that the LCD is facing you again.
    • Gently lift the LCD monitor up and out.
    • Remove the black plastic tab.
    Chiedi a FixBot
    Aggiungi Commento
  14. IBM ThinkPad A30 Fan Replacement, Fan: passo 14, immagine 1 di 1
    • Remove the following screws from the fan retention bracket:
    • Single 5.6 mm screw.
    • Three 16.1 mm screws.
    Chiedi a FixBot
    Aggiungi Commento
  15. IBM ThinkPad A30 Fan Replacement: passo 15, immagine 1 di 1
    • Lift the heatsink bracket up.
    Chiedi a FixBot
    Aggiungi Commento
  16. IBM ThinkPad A30 Fan Replacement: passo 16, immagine 1 di 3 IBM ThinkPad A30 Fan Replacement: passo 16, immagine 2 di 3 IBM ThinkPad A30 Fan Replacement: passo 16, immagine 3 di 3
    • Be careful not to pull too hard. There is a cable attached to the fan.
    • Lift the fan/heatsink assembly up.
    • Locate the fan power cable and pull upwards near the connector.
    • Remove the fan/heatsink assembly.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Jessica
Membro da: 10/06/10
162 Reputazione
7 guide realizzate
Cal Poly, Team 4-44, Amido Fall 2010 Membro di Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 Membri
26 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 11
Ultimi 30 giorni: 38
Tutti i Tempi: 3,147
