Salta al contenuto principale
Huawei Mate 8 Display Replacement
Cosa ti serve
  1. Huawei Mate 8 Display Replacement, Back Cover: passo 1, immagine 1 di 2 Huawei Mate 8 Display Replacement, Back Cover: passo 1, immagine 2 di 2
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Display Replacement: passo 2, immagine 1 di 1
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Display Replacement: passo 3, immagine 1 di 2 Huawei Mate 8 Display Replacement: passo 3, immagine 2 di 2
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Display Replacement: passo 4, immagine 1 di 3 Huawei Mate 8 Display Replacement: passo 4, immagine 2 di 3 Huawei Mate 8 Display Replacement: passo 4, immagine 3 di 3
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: passo 5, immagine 1 di 3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: passo 5, immagine 2 di 3 Huawei Mate 8 Display Replacement, Daughterboard interconnect cable: passo 5, immagine 3 di 3
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  6. Huawei Mate 8 Display Replacement: passo 6, immagine 1 di 3 Huawei Mate 8 Display Replacement: passo 6, immagine 2 di 3 Huawei Mate 8 Display Replacement: passo 6, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  7. Huawei Mate 8 Display Replacement: passo 7, immagine 1 di 1
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  8. Huawei Mate 8 Display Replacement: passo 8, immagine 1 di 2 Huawei Mate 8 Display Replacement: passo 8, immagine 2 di 2
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  9. Huawei Mate 8 Display Replacement: passo 9, immagine 1 di 1
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  10. Huawei Mate 8 Display Replacement, Battery: passo 10, immagine 1 di 1
    • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
    • Get a good grip on the pull tab near the power button and peel out the adhesive strip by steadily pulling at the tab in a flat angle.
    • If the adhesive strip rips, grab and twist it around the tweezer tips a couple of times and then continue.
  11. Huawei Mate 8 Display Replacement: passo 11, immagine 1 di 3 Huawei Mate 8 Display Replacement: passo 11, immagine 2 di 3 Huawei Mate 8 Display Replacement: passo 11, immagine 3 di 3
    • Do not bend or puncture the battery, damage to the cell can cause battery fires.
    • Heat an iOpener and place it on the phone for about a minute to loosen the remaining adhesive.
    • Carefully insert the flat end of a spudger to separate any remaining adhesive at the top of the battery.
  12. Huawei Mate 8 Display Replacement: passo 12, immagine 1 di 2 Huawei Mate 8 Display Replacement: passo 12, immagine 2 di 2
    • Lift the top end of the battery to pull the battery off of the remaining adhesive strip.
    • When reassembling your phone, apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
    • Never reinstall a battery that has been bent or damaged during removal.
  13. Huawei Mate 8 Display Replacement, Display: passo 13, immagine 1 di 1
    • Remove the four Phillips #00 screws holding the daughterboard and loudspeaker to the phone.
  14. Huawei Mate 8 Display Replacement: passo 14, immagine 1 di 2 Huawei Mate 8 Display Replacement: passo 14, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the loudspeaker connector cable.
    • Use the tip of a spudger to lift the daughterboard from the phone.
  15. Huawei Mate 8 Display Replacement: passo 15, immagine 1 di 2 Huawei Mate 8 Display Replacement: passo 15, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Insert the flat end of a spudger under the loudspeaker at the gap on the left side.
    • Work the spudger under the loudspeaker to seperate it from the adhesive and remove the loudspeaker.
    • Use tweezers to take the vibration unit out of its housing.
  16. Huawei Mate 8 Display Replacement: passo 16, immagine 1 di 1
    • Remove the eight Phillips #00 screws securing the motherboard to the phone.
  17. Huawei Mate 8 Display Replacement: passo 17, immagine 1 di 2 Huawei Mate 8 Display Replacement: passo 17, immagine 2 di 2
    • Remove the bracket from the rear camera flex cable.
    • Use tweezers to disconnect the antenna cable.
  18. Huawei Mate 8 Display Replacement: passo 18, immagine 1 di 3 Huawei Mate 8 Display Replacement: passo 18, immagine 2 di 3 Huawei Mate 8 Display Replacement: passo 18, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the volume and power flex cable on the bottom left side of the mainboard.
    • Work the flat end of a spudger under the top right side of the mainboard to pry it out.
    • Remove the mainboard.
  19. Huawei Mate 8 Display Replacement: passo 19, immagine 1 di 2 Huawei Mate 8 Display Replacement: passo 19, immagine 2 di 2
    • Remove the antenna interconnect cable.
    • Remove the power and volume switch assembly.
  20. Huawei Mate 8 Display Replacement: passo 20, immagine 1 di 3 Huawei Mate 8 Display Replacement: passo 20, immagine 2 di 3 Huawei Mate 8 Display Replacement: passo 20, immagine 3 di 3
    • Use tweezers to remove the earpiece speaker.
    • Remove the red rubber gasket.
    • Remove the ambient light and proximity sensor.
Conclusione
Altre 9 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
123 Membri
23.758 Guide realizzate
1Commento della guida
Tidy. Really tidy like.
Marc Vestabule - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 57
Tutti i Tempi: 6,544
