Salta al contenuto principale
How to fix Mobee Magic Mouse disconnection issues
Cosa ti serve
Istruzioni Video
Linea Traguardo
Altre 31 persone hanno completato questa guida.
Dragon Upstream Consulting Limited Membro di Dragon Upstream Consulting Limited
Business
Membro di 1
6 guide realizzate
5Commenti sulla guida
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Rispondi Condividi
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Rispondi Condividi
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Rispondi Condividi
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Rispondi Condividi
What is the screw type and size for the Magic Mouse battery pack? They're so small I can barely see them! Are they tiny Allen/Hex heads?
Jeffrey Powell - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 22
Ultimi 30 giorni: 107
Tutti i Tempi: 41,710
