Salta al contenuto principale
How to create a ChromeOS Recovery USB Drive
Cosa ti serve
    • In order to make your recovery device, you will need the following items.
    • 1 x USB Drive or SD Card (8 GB is the minimum)
    • Any content that is stored on this drive will be erased during the next few steps. Be sure to back up any content you want saved, or make sure this is a drive you are going to use for future devices.
    • 1 x computer running the Google Chrome Browser, or Chrome OS.
    Chiedi a FixBot
    Aggiungi Commento
  1. How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: passo 2, immagine 1 di 2 How to create a ChromeOS Recovery USB Drive, Download the Recovery Utility: passo 2, immagine 2 di 2
    • Open Google Chrome and navigate to the Chrome Web Store and download the Chromebook Recovery Utility extension.
    • Add the utility to Chrome and launch it. You will be greeted with this page.
    Chiedi a FixBot
    Aggiungi Commento
  2. How to create a ChromeOS Recovery USB Drive, Enter your Chromebook Model Number: passo 3, immagine 1 di 1
    • Click on "Get started" and you will be prompted to enter the model of your Chromebook.
    • You have the option of either entering the code that is on the device's recovery screen, or choosing from the model list.
    Chiedi a FixBot
    Aggiungi Commento
  3. How to create a ChromeOS Recovery USB Drive, Insert your Removable Media: passo 4, immagine 1 di 1
    • Plug in your spare 8 GB USB Drive and select it from the dropdown menu.
    • Any content that is stored on the drive will be erased during the next few steps. Make sure that the drive is empty, or does not have any data that you don't want to lose.
    Chiedi a FixBot
    Aggiungi Commento
  4. How to create a ChromeOS Recovery USB Drive, Create Recovery Image: passo 5, immagine 1 di 1
    • You will be presented with a screen that shows the drive you selected. Click on the "Create now" button and the processes will begin.
    • Do not remove the drive while the process is taking place. The process will take about 5 minutes to complete and you will be prompted when the recovery drive is finished.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
If you intend on reusing the drive for storing files you will need to use the Recover Utility application to erase the data on the drive, and you will need to reformat it with a recovery tool.
Altre 101 persone hanno completato questa guida.
Jacob Mehnert
Membro da: 10/18/21
49.136 Reputazione
51 guide realizzate
iFanatics Membro di iFanatics
Community
69 Membri
237 guide realizzate
15Commenti sulla guida
Thanks only this is working all the other instructions on google didnt work… Direct and simple instructions
idide akeh - Rispondi Condividi
I'm glad to hear that this guide helped you out!
Jacob Mehnert - Rispondi Condividi
Hello....I followed all you said here yet my USB flash drives got corrupted after the recovery utility completed
Amos - Rispondi Condividi
Hello, you might need to wipe the USB drive and attempt to install the recovery tool again. You might also want to check that the drive is formatted to FAT32. Other formats have been known to cause errors with the recovery tool.
Does it matter if it’s a 2.0 or 3.0 USB drive???
Josh Knapp - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 22
Ultimi 7 giorni: 137
Ultimi 30 giorni: 650
Tutti i Tempi: 59,289
