Salta al contenuto principale
How to clean Microtek ScanMaker 5900 glass
Cosa ti serve
    1. How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: passo 1, immagine 1 di 3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: passo 1, immagine 2 di 3 How to clean Microtek ScanMaker 5900 glass, Remove serial port connection: passo 1, immagine 3 di 3
      • Loosen the screws on the serial port by turning them counter clockwise by hand.
      • After loosening the screws, pull the serial port out.
      Chiedi a FixBot
      Aggiungi Commento
    2. How to clean Microtek ScanMaker 5900 glass, Remove Lid: passo 2, immagine 1 di 3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: passo 2, immagine 2 di 3 How to clean Microtek ScanMaker 5900 glass, Remove Lid: passo 2, immagine 3 di 3
      • Lift lid to its vertical position.
      • Pull lid straight up to remove it from the scanner.
      Chiedi a FixBot
      Aggiungi Commento
    1. How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: passo 3, immagine 1 di 3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: passo 3, immagine 2 di 3 How to clean Microtek ScanMaker 5900 glass, Detach plastic latches: passo 3, immagine 3 di 3
      • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
      Chiedi a FixBot
      Aggiungi Commento
    2. How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: passo 4, immagine 1 di 3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: passo 4, immagine 2 di 3 How to clean Microtek ScanMaker 5900 glass, Continue latch detachment: passo 4, immagine 3 di 3
      • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
      • Go all the way along the chassis until you can lift the upper lid.
      Chiedi a FixBot
      Aggiungi Commento
    3. How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: passo 5, immagine 1 di 3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: passo 5, immagine 2 di 3 How to clean Microtek ScanMaker 5900 glass, Fully remove the upper lid: passo 5, immagine 3 di 3
      • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
      • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
      • Grab the ribbon cable and gently pull it out of its slot with your fingers.
      • The upper lid can now safely be removed from the bottom lid.
      Chiedi a FixBot
      Aggiungi Commento
    1. How to clean Microtek ScanMaker 5900 glass, How to clean Microtek ScanMaker 5900 glass: passo 6, immagine 1 di 1
      • Using a soft lint-free cloth clean the surface glass of dust, finger prints and other debris.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 6-9, Regan Fall 2011 Membro di Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membri
55 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 45
Tutti i Tempi: 3,029
