Salta al contenuto principale
How to True Bicycle wheels
Cosa ti serve
  1. How to True Bicycle wheels, How to True Bicycle wheels: passo 1, immagine 1 di 2 How to True Bicycle wheels, How to True Bicycle wheels: passo 1, immagine 2 di 2
    • Fit the wheel into the wheel truing stand. It doesn't matter which way the wheel is facing.
    • The wheel should be snug and securely fixed to the stand.
    • Tighten the quick-release nut and lever, making sure that there is no room for the wheel to wiggle in the truing stand.
    Chiedi a FixBot
    Aggiungi Commento
  2. How to True Bicycle wheels: passo 2, immagine 1 di 2 How to True Bicycle wheels: passo 2, immagine 2 di 2
    • Bring the calipers up until the teeth are are about half an inch from the metal rim of the wheel.
    • Start the wheel spinning slowly.
    • Slowly tighten the calipers until they contact the wheel on one side or the other.
    Chiedi a FixBot
    Aggiungi Commento
  3. How to True Bicycle wheels: passo 3, immagine 1 di 2 How to True Bicycle wheels: passo 3, immagine 2 di 2
    • Loosen the spoke nipples that attach to the same side of the wheel that the caliper is touching. At the same time, tighten the spokes that attach to the opposite side of the hub.
    • As a starting point, turn all the spokes half of a turn for each of the spokes near the caliper contact point.
    • In the photo, the red marked spokes are being tightened, and the blue marked spokes are being loosened. This will shift the rim closer to the viewer.
    • Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until the caiplers touch both sides of the rim evenly at every point on the rim.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
The wheel should spin without wobbling from side to side or wavering up and down
Altre 3 persone hanno completato questa guida.
Brett Hartt
Membro da: 04/12/10
132.245 Reputazione
144 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
28.230 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 17
Ultimi 30 giorni: 62
Tutti i Tempi: 6,284
