Salta al contenuto principale
How to Remove the Stand on a PlayStation 5
Cosa ti serve
  1. How to Remove the Stand on a PlayStation 5, Remove the stand screw: passo 1, immagine 1 di 1
    • If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
    • If your PlayStation 5 is in its horizontal orientation, skip to Step 6.
    • Work on a flat surface to prevent your PlayStation from falling over.
    • Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
  2. How to Remove the Stand on a PlayStation 5, Remove the vertical stand: passo 2, immagine 1 di 2 How to Remove the Stand on a PlayStation 5, Remove the vertical stand: passo 2, immagine 2 di 2
    • Lift straight up to remove the stand.
  3. How to Remove the Stand on a PlayStation 5, Store the stand screw: passo 3, immagine 1 di 2 How to Remove the Stand on a PlayStation 5, Store the stand screw: passo 3, immagine 2 di 2
    • Insert the screw into the cubby on the bottom of the stand.
  4. How to Remove the Stand on a PlayStation 5, Cap the screw hole: passo 4, immagine 1 di 3 How to Remove the Stand on a PlayStation 5, Cap the screw hole: passo 4, immagine 2 di 3 How to Remove the Stand on a PlayStation 5, Cap the screw hole: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a pair of tweezers or your fingernail to remove the cap from the cubby.
    • Use your finger to press the cap into the screw hole.
  5. How to Remove the Stand on a PlayStation 5, Close the cubby: passo 5, immagine 1 di 3 How to Remove the Stand on a PlayStation 5, Close the cubby: passo 5, immagine 2 di 3 How to Remove the Stand on a PlayStation 5, Close the cubby: passo 5, immagine 3 di 3
    • Twist the stand counterclockwise to close the cubby.
  6. How to Remove the Stand on a PlayStation 5, Remove the horizontal stand: passo 6, immagine 1 di 2 How to Remove the Stand on a PlayStation 5, Remove the horizontal stand: passo 6, immagine 2 di 2
    • If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
    • Lift the stand straight up to remove it.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
Altre 5 persone hanno completato questa guida.
Robert Boyd
Membro da: 02/01/21
31.655 Reputazione
94 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 24
Ultimi 7 Giorni: 125
Ultimi 30 Giorni: 569
Tutti i Tempi: 57,302
