Introduzione
Use this guide to remove the freezer drawer on your LG refrigerator.
This guide will work for most LG refrigerators. This guide is written with an LG model LFX25973 refrigerator. If you have a different model, you may encounter some minor disassembly differences, but the overall repair process will be the same.
The freezer drawer allows convenient access to the freezer contents and also allows for easy organization.
You will need to remove the freezer drawer to access a number of components in the cooling system. Among them are the evaporator cover, the evaporator fan, the freezer ice maker, the defrost heater and two different thermistors. You may need to remove it to replace the drawer seal as well.
Cosa ti serve
Unplug your refrigerator before you begin your repair.
Condenser fan motor
Compressor motor and thermal overload device
Water supply valve assembly
Lift and remove the upper pull-out drawer.
Lift and remove the main drawer bin.
Use your finger or a flat-blade screwdriver to depress the two locking tabs on the right drawer rail cover.
Lift the cover off of the rail and remove it.
Repeat this procedure for the left drawer rail cover.
Hold the drawer rail cover flush against the side of the drawer rail.
Push the rail cover straight downward to install. It should click into place.
Use a Phillips screwdriver to remove the screw securing the drawer to each of the drawer slides.
