Introduzione
Use this guide to open your Razer Kishi for repairs and modding.
Both controller sides of the Razer Kishi are almost identical in construction. The opening process is similar on both sides, therefore we will only show the right side in this guide.
Cosa ti serve
For the right side, remove the five Y0 screws securing the right side of the controller.
Four 9.2 mm screws
One 7.2 mm screw
If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
Four 9.2 mm screws
One 7.2 mm screw
Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
Slide the opening pick along the right edge to loosen the plastic clips.
Slide the opening pick along the top edge to loosen the remaining plastic clips.
Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
Pull the cable out of the socket.
Opening didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Altre 4 persone hanno completato questa guida.
Un commento
Is the left side glued? Because I can't separate the left side, as it is sealed shut like it was glued together.
