Salta al contenuto principale
How to Open Your Logitech M310 Wireless Mouse
Cosa ti serve
  1. How to Open Your Logitech M310 Wireless Mouse, Turn off your mouse: passo 1, immagine 1 di 1
    • Before starting, flip the power switch on the bottom of your mouse to the left, so it's in the OFF position.
  2. How to Open Your Logitech M310 Wireless Mouse, Remove the battery cover: passo 2, immagine 1 di 3 How to Open Your Logitech M310 Wireless Mouse, Remove the battery cover: passo 2, immagine 2 di 3 How to Open Your Logitech M310 Wireless Mouse, Remove the battery cover: passo 2, immagine 3 di 3
    • Press down on the battery cover with your thumb and slide it away from the mouse to unclip it.
    • Remove the battery cover.
  3. How to Open Your Logitech M310 Wireless Mouse, Remove the battery: passo 3, immagine 1 di 3 How to Open Your Logitech M310 Wireless Mouse, Remove the battery: passo 3, immagine 2 di 3 How to Open Your Logitech M310 Wireless Mouse, Remove the battery: passo 3, immagine 3 di 3
    • Use your fingers to lift the end of the battery and slide it out of its recess.
    • During reassembly, slide the battery in negative (-) end first, as shown on the sticker in the recess.
  4. How to Open Your Logitech M310 Wireless Mouse, Remove the case screws: passo 4, immagine 1 di 3 How to Open Your Logitech M310 Wireless Mouse, Remove the case screws: passo 4, immagine 2 di 3 How to Open Your Logitech M310 Wireless Mouse, Remove the case screws: passo 4, immagine 3 di 3
    • Use a Phillips screwdriver to remove the two 5.5 mm‑long screws securing the two halves of the mouse together.
  5. How to Open Your Logitech M310 Wireless Mouse, Separate the mouse halves: passo 5, immagine 1 di 3 How to Open Your Logitech M310 Wireless Mouse, Separate the mouse halves: passo 5, immagine 2 di 3 How to Open Your Logitech M310 Wireless Mouse, Separate the mouse halves: passo 5, immagine 3 di 3
    • With one hand, hold the top half of the mouse.
    • With your free hand, insert a finger into the battery recess on the bottom half.
    • Pull the bottom half of the mouse away from the top half to unclip and remove it.
    • During reassembly, slide the bottom edge of the mouse into place first, and then squeeze the two shells together to engage all the clips.
Conclusione
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Spencer Day
Membro da: 09/14/22
150.212 Reputazione
995 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 44
Tutti i Tempi: 77
