Salta al contenuto principale
How to Install Ubuntu Linux
Cosa ti serve
    1. How to Install Ubuntu Linux, Download Ubuntu: passo 1, immagine 1 di 1
      Chiedi a FixBot
      Aggiungi Commento
    2. How to Install Ubuntu Linux, Burn to Disk: passo 2, immagine 1 di 2 How to Install Ubuntu Linux, Burn to Disk: passo 2, immagine 2 di 2
      • Use disk burning software like ImgBurn to burn Ubuntu to a DVD, or you can use a USB flash drive instead. If you use a flash drive, download UNetbootin and create your installation media.
      • You do not need to burn Ubuntu to a disk if you are using a virtual machine.
      Chiedi a FixBot
      Aggiungi Commento
    3. How to Install Ubuntu Linux, Boot to installation media: passo 3, immagine 1 di 1
      • I recommend trying Ubuntu in a virtual machine, which is what I did.
      • If you are using a real computer, you may need to configure the BIOS or press a key on system startup. If you need to change the BIOS settings, set any Optical Drives or USB CD-ROM drives as the first boot priority.
      • If you want to use a virtual machine, set CD/DVD as the first boot priority and mount the iso file to the machine. There is plenty of virtualization software out there, like VirtualBox.
      • If you have successfully booted into the installation media, you will see this picture.
      • Click on the big "Install Ubuntu" button.
      Chiedi a FixBot
      Aggiungi Commento
    4. How to Install Ubuntu Linux, Install Ubuntu: passo 4, immagine 1 di 1
      • After a screen asking about additional software, you will asked what you would like to do with your hard disk.
      • If the installer refers to any sort of dual-booting, you must quit the installer and make unallocated space on your hard disk somehow. (See warning for info.)
      • If you are experienced with partitions, you may use this partition editor.
      • If you decide to use the partition editor, please be very careful. Partitions made with this partition editor can cause any other operating systems to become inaccessible.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
That's it! Now you can try Ubuntu all you want.
Altre 7 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 22
Tutti i Tempi: 1,578
