Salta al contenuto principale
How to Fix a Car Dent
Cosa ti serve
    1. How to Fix a Car Dent, How to Fix a Car Dent: passo 1, immagine 1 di 2 How to Fix a Car Dent, How to Fix a Car Dent: passo 1, immagine 2 di 2
      • Be sure that the bucket or pot is big enough to fit the vacuum that will be used for this procedure
      • It is suggested when cutting a hole into the bottom of the bucket, you use a Utility Knife and not rush through this step
      • The use of a Utility Knife over a normal knife makes it safer for everyone, and gives a more precise cut
      Chiedi a FixBot
      Aggiungi Commento
    2. How to Fix a Car Dent: passo 2, immagine 1 di 1
      • Insert the vacuum into the hole at the bottom of the bucket to be sure it fits
      • If the hole is too small and the vacuum cannot fit within the hole, go back to step one and attempt to enlarge the hole
      • If the hole appears to be too large, one may want to consider going back to step one with a new bucket
      Chiedi a FixBot
      Aggiungi Commento
    3. How to Fix a Car Dent: passo 3, immagine 1 di 1
      • Be sure to wipe down the area that will be worked on with a dry cotton rag
      • The dirt and oil that may be on the surface of your car can make it harder to complete the steps that follow. Due to the fact that dirt and oil can cause issues with the effectiveness of how tape may stick.
      Chiedi a FixBot
      Aggiungi Commento
    4. How to Fix a Car Dent: passo 4, immagine 1 di 3 How to Fix a Car Dent: passo 4, immagine 2 di 3 How to Fix a Car Dent: passo 4, immagine 3 di 3
      • Place the bucket over the dent that needs to be fixed
      • Start by lightly taping down the bucket with painters tape - this allows the bucket to be held up and allow the rest of the tapping easier to do
      • Go over the edges of the bucket with duct tape until you are sure that it is airtight onto the car
      Chiedi a FixBot
      Aggiungi Commento
    5. How to Fix a Car Dent: passo 5, immagine 1 di 1
      • Place the vacuum into the hole at the bottom of the bucket
      • At this point be sure to allow some time for suction to occur and listen for a small popping noise
      • The popping noise that needs to be listened for is the dent in your car popping out from the suction of the vacuum
      Chiedi a FixBot
      Aggiungi Commento
    6. How to Fix a Car Dent: passo 6, immagine 1 di 1
      • At times the way the vacuum is positioned can affect the suction
      • If after some time there is no popping noise, adjusting the placement of the vacuum is recommended
      • After adjusting the vacuum allow time for suction again and listen for a popping noise to know when your dent is fixed
      Chiedi a FixBot
      Aggiungi Commento
Linea Traguardo
Altre 7 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 8
Ultimi 7 giorni: 59
Ultimi 30 giorni: 224
Tutti i Tempi: 8,245
