Salta al contenuto principale
How to Clean Inside a Washing Machine
Guida video
Questa guida è stata trascritta da un video di YouTube.
Cosa ti serve
      • Unplug the washing machine before cleaning.
      • Don’t bypass the lid switch, door lock, or any other safety interlock while the washer is running.
      • Put on nitrile gloves and safety glasses, and avoid breathing powder dust.
      • Make sure the drum is empty, with no clothes or detergent.
      • Don’t mix this method with chlorine bleach or other cleaners.
      Chiedi a FixBot
      Aggiungi Commento
      • Measure about one cup of citric acid for a heavy-duty clean on a dirty or smelly washer.
      • Measure about one quarter cup of oxygenated bleach powder for a heavy-duty clean.
      • Use about one half cup of citric acid if you clean the washer often and only need maintenance cleaning.
      • Use about one tablespoon of oxygenated bleach powder for maintenance cleaning.
      • Consider using up to two cups of citric acid if the washer has never been cleaned and has heavy buildup.
      Chiedi a FixBot
      Aggiungi Commento
      • Pour the measured citric acid into the empty wash tub.
      • Pour the measured oxygenated bleach into the empty wash tub.
      • Run a normal wash cycle or a washer-cleaning cycle with hot water and no laundry.
      • Let the washer agitate so the mixture can circulate and start breaking down soap scum and moldy residue.
      Chiedi a FixBot
      Aggiungi Commento
      • Use the longest wash cycle you can so the solution has more time to work.
      • Pause the cycle and let the solution soak if the washer allows it.
      • Short cycles don’t leave the mixture in the washer long enough to eat buildup as effectively.
      Chiedi a FixBot
      Aggiungi Commento
      • Check for grime at the extreme bottom or at areas that don’t get washed by normal water levels.
      • Add citric acid, fill the washer only slightly with water, and let it soak to loosen bottom debris.
      • Run a wash cycle after soaking to flush the loosened buildup out of the tub.
      Chiedi a FixBot
      Aggiungi Commento
      • Use a scrub brush to break loose any remaining grime that didn’t wash away.
      • Use a condenser brush to reach and scrub tight spaces between the inner and outer tub if you can access them safely.
      • Remove loosened debris by hand so it doesn’t settle back into the washer.
      Chiedi a FixBot
      Aggiungi Commento
      • Measure about one third cup of citric acid and about one half teaspoon of oxygenated bleach powder.
      • Put the mixture into the empty drum, and run a hot rinse-and-drain cycle to flush the solution through the drain system.
      • Use this when the washer drains slowly or when odors seem strongest near the drain.
      Chiedi a FixBot
      Aggiungi Commento
      • Wipe the inside surfaces you can reach, especially under the top rim or around the door opening.
      • Leave the lid or door open to help the washer dry out and reduce mold regrowth.
      • Repeat maintenance cleaning with one half cup to one cup of citric acid every two weeks to once a month.
      • Run a larger dose if the washer has years of buildup or if the first cleaning doesn’t fully remove odors.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
If odors or visible buildup persist, repeat the deep-clean dose, extend the soak time, and scrub the remaining residue you can safely reach before running another hot cycle. Once the washer is clean, keep the lid or door open between loads and repeat maintenance cleaning regularly to slow new buildup. Repair didn't go as planned? Ask our Answers community for help.
Ben Schlichter
Membro da: 01/21/25
7.128 Reputazione
224 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 12
Ultimi 7 giorni: 42
Ultimi 30 giorni: 236
Tutti i Tempi: 972
