Salta al contenuto principale
How to Check Battery Health Using CROSH
      • From your Desktop use the key combination Ctrl + Alt + T
      Chiedi a FixBot
      Aggiungi Commento
      • In the CROSH terminal type in battery_test [< test length >]
      • The test length is measured in seconds. if no number is put in, then the test length will default to 300 seconds.
      Chiedi a FixBot
      Aggiungi Commento
      • You can also use the command battery_firmware info to get additional information about your battery's including serial number, chemistry, and design capacity.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
This command is extremely useful for determining if your Chromebook's battery is operating at peak performance, of if there is an issue with the battery.
Altre 5 persone hanno completato questa guida.
Jacob Mehnert
Membro da: 10/18/21
49.554 Reputazione
52 guide realizzate
iFanatics Membro di iFanatics
Community
69 Membri
478 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 17
Ultimi 30 giorni: 87
Tutti i Tempi: 6,063
