Salta al contenuto principale
How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro
  1. How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Align the graphite sheet: passo 1, immagine 1 di 3 How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Align the graphite sheet: passo 1, immagine 2 di 3 How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Align the graphite sheet: passo 1, immagine 3 di 3
    • Before applying the new graphite sheet, it's helpful to see how it will be oriented on your phone.
    • Hold the graphite sheet so the clear liner is on the bottom and place it over your phone to find the proper alignment.
    • The sections of the graphite sheet with three flaps will go over the rear camera assembly.
  2. How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Remove the clear liner: passo 2, immagine 1 di 1
    • Remove the larger clear liner from the back of the sheet to expose the adhesive.
  3. How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Place the graphite sheet: passo 3, immagine 1 di 3 How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Place the graphite sheet: passo 3, immagine 2 di 3 How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Place the graphite sheet: passo 3, immagine 3 di 3
    • Be very careful during this step! Once the graphite sheet sticks to your phone, you won't be able to reposition it. You'll have to start over with a new sheet if it gets applied incorrectly.
    • Gently place the top edge of the sheet onto the frame. Use the frame's lip to help position the sheet.
    • Carefully lay the rest of the sheet onto your phone.
  4. How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Secure the graphite sheet: passo 4, immagine 1 di 3 How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Secure the graphite sheet: passo 4, immagine 2 di 3 How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Secure the graphite sheet: passo 4, immagine 3 di 3
    • The sheet needs to be firmly secured to your phone before removing any liners to prevent it from pulling up and misaligning in the next step.
    • Use your fingers to firmly press down and secure the graphite sheet to your phone.
    • Be very careful not to damage the spring contacts near the edges of your phone.
  5. How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Remove the blue liner: passo 5, immagine 1 di 3 How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Remove the blue liner: passo 5, immagine 2 di 3 How to Apply a New Graphite Sheet in Your Google Pixel 8 Pro, Remove the blue liner: passo 5, immagine 3 di 3
    • Gently peel up and remove the remaining blue liner.
    • If any part of the sheet starts to peel up with the liner, gently lay it back on the frame and use your fingers to secure it.
Conclusione
Spencer Day
Membro da: 09/14/22
55.203 Reputazione
408 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.430 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 41
Tutti i Tempi: 308
