Salta al contenuto principale
How to Apply New Back Glass Adhesive in Your Google Pixel Fold
Cosa ti serve
  1. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Align the adhesive: passo 1, immagine 1 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Align the adhesive: passo 1, immagine 2 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Align the adhesive: passo 1, immagine 3 di 3
    • Before removing any liners, check if the adhesive matches the frame.
    • The clear liner should face the frame.
    • Look for cutouts in the liner to help orient the adhesive.
  2. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the adhesive: passo 2, immagine 1 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the adhesive: passo 2, immagine 2 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the adhesive: passo 2, immagine 3 di 3
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel off the new adhesive strip from its clear liner.
    • Align the adhesive over the frame, starting with the top right and bottom right edges.
    • Place the adhesive over the perimeter of the frame.
  3. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 3, immagine 1 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 3, immagine 2 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 3, immagine 3 di 3
    • Use flat end of a spudger, or your fingers, to press down the adhesive to adhere it to the frame.
  4. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the large liner: passo 4, immagine 1 di 2 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the large liner: passo 4, immagine 2 di 2
    • Peel up the segmented tab at the bottom right corner of the large blue liner.
  5. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 5, immagine 1 di 2 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 5, immagine 2 di 2
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
  6. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Reconnect the back glass: passo 6, immagine 1 di 2 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Reconnect the back glass: passo 6, immagine 2 di 2
    • Support the back glass with your hand or prop it up on something sturdy.
    • Reconnect the back glass cable.
    • Use a Torx Plus 3IP driver to refasten the middle bracket.
  7. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the secondary liner: passo 7, immagine 1 di 2 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Peel up the secondary liner: passo 7, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers, or your fingers, to peel up either one of the tabs at the top right corner of the secondary liner.
    • If the adhesive starts separating, use a spudger to hold it down while peeling.
  8. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 8, immagine 1 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 8, immagine 2 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 8, immagine 3 di 3
    • Lift the tab and peel off the secondary liner to expose the top adhesive.
  9. How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the back glass: passo 9, immagine 1 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the back glass: passo 9, immagine 2 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold, Apply the back glass: passo 9, immagine 3 di 3
    • Align the back glass over its cutout in the frame.
    • Place a long edge of the back glass on the frame, making sure there are no gaps or jutting adhesive.
    • Place the other long edge of the back glass on the frame.
  10. How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 10, immagine 1 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 10, immagine 2 di 3 How to Apply New Back Glass Adhesive in Your Google Pixel Fold: passo 10, immagine 3 di 3
    • Press down along the perimeter of the back glass to adhere it to the frame.
    • Let the phone sit a few hours for the adhesive to cure.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
212.584 Reputazione
1.039 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.608 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 30
Tutti i Tempi: 546
