Salta al contenuto principale
How to Fix A Loose Bicycle Chain
Cosa ti serve
    1. How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: passo 1, immagine 1 di 2 How to  Fix A Loose Bicycle Chain, How to  Fix A Loose Bicycle Chain: passo 1, immagine 2 di 2
      • Determine if your chain is loose. As shown in the pictures, the bike chain is hanging low; this is an excellent indication that your bike chain is loose.
      • Your bike might have oil all over its chain and gear, so it's best to wear gloves.
      Chiedi a FixBot
      Aggiungi Commento
    2. How to  Fix A Loose Bicycle Chain: passo 2, immagine 1 di 1
      • Use a bike stand or wall to help keep your bike from falling.
      Chiedi a FixBot
      Aggiungi Commento
    3. How to  Fix A Loose Bicycle Chain: passo 3, immagine 1 di 2 How to  Fix A Loose Bicycle Chain: passo 3, immagine 2 di 2
      • Loosen both nuts on either side of the rear wheel using a socket wrench, rotating the wrench from left to right.
      • Be sure to not fully unscrew the nut or else the rear wheel will no longer be connected to the bike and you will have to spend time reassembling it.
      Chiedi a FixBot
      Aggiungi Commento
    4. How to  Fix A Loose Bicycle Chain: passo 4, immagine 1 di 2 How to  Fix A Loose Bicycle Chain: passo 4, immagine 2 di 2
      • Hold the end of the bike wheel with one hand and the bike's frame with your other hand.
      • Pull the wheel back from the frame.
      • Hold the wheel in place while proceeding to the next step.
      • While holding the wheel back, your chain should stop hanging.
      Chiedi a FixBot
      Aggiungi Commento
    5. How to  Fix A Loose Bicycle Chain: passo 5, immagine 1 di 2 How to  Fix A Loose Bicycle Chain: passo 5, immagine 2 di 2
      • Tighten both of the loose nuts using a socket wrench, rotating the wrench from right to left, while still holding the wheel back.
      Chiedi a FixBot
      Aggiungi Commento
    6. How to  Fix A Loose Bicycle Chain: passo 6, immagine 1 di 2 How to  Fix A Loose Bicycle Chain: passo 6, immagine 2 di 2
      • Check if your chain is still loose. As shown in the pictures, your chain should have more tension making it straight rather than hanging.
      • Do not place your fingers too close to the bike gear. It may accidentally spin depending on how your bike works and trap your fingers.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
After reading this guide you will never have trouble with a loose chain again.
Altre 8 persone hanno completato questa guida.
Carlos Ortiz
Membro da: 01/30/22
325 Reputazione
Una guida realizzata
3Commenti sulla guida
The steps to tight the loosen chain are good. I will try it for my cycle. https://www.youtube.com/watch?v=JMdihKgC... speed internal gear bicycle). This video reflect your steps in a good manner
Kulasekara Pandian - Rispondi Condividi
Muchas gracias ! Me sirve muy buena información sin rodeos, y directo a los que se necesita gracias.
Martin alejandro Eligio avalos - Rispondi Condividi
Gracias por sus enseñanzas muchas bendiciones para todos ustedes.
Pablo Ventura - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 9
Ultimi 7 giorni: 83
Ultimi 30 giorni: 391
Tutti i Tempi: 32,918
