Salta al contenuto principale
How To Maintain Your Washing Machine
Cosa ti serve
      • Unplug the washing machine before starting any cleaning or maintenance.
      • Prepare a mild chlorine-based cleaner, an acid-based cleaner, citric acid, dishwasher tablets, a soft brush, a sponge, and a cloth.
      • Keep a container or small bowl handy to catch residual water from the filters.
      Chiedi a FixBot
      Aggiungi Commento
      • For cleaning you will need: bleaching and stain remover agent, acid-based cleaner, brushes, container to catch water from filter, sponge, coin/key, two washing machine tablets, citric acid
      • Pull out the detergent drawer fully and remove any detachable parts, especially the softener compartment.
      • Soak and scrub the drawer to remove residues, ensuring the siphon area for the softener is not clogged.
      • Clean the interior slot where the drawer slides in using a brush or cloth to remove buildup.
      • Confirm all parts are clear of debris before setting the drawer aside to dry or placing it in a dishwasher for a thorough clean.
      Chiedi a FixBot
      Aggiungi Commento
      • Check for objects like coins or small items trapped around or under the seal.
      • Apply a chlorine-based cleaner to areas with visible mold or residue, focusing on all folds and edges.
      • Wipe thoroughly with a cloth or sponge and let the cleaner sit briefly to remove stubborn buildup.
      • Remember that a hot cycle with citric acid will neutralize any remaining chlorine later.
      Chiedi a FixBot
      Aggiungi Commento
      • Use an acid-based cleaner or mild solution to wipe away lint and residues from the door glass.
      • Wipe it dry to ensure clarity and prevent streaks.
      Chiedi a FixBot
      Aggiungi Commento
      • Locate the small drain hose or release valve near the filter cover where water can be emptied before filter removal.
      • Drain residual water into a container or bowl to prevent spills.
      • Open the filter cover using a coin or small tool, then remove and inspect the filter for debris.
      • Use a brush or cloth to clean the filter thoroughly and check for trapped items.
      • Reinstall the filter securely to avoid leaks during operation.
      Chiedi a FixBot
      Aggiungi Commento
      • Turn off the water supply and disconnect the fill hose from the back of the machine.
      • Locate and remove the small mesh inlet filter to clear sediment and debris.
      • Rinse or gently brush the filter, then reinsert it and reconnect the hose firmly.
      • Ensure no leaks by tightening the connection properly.
      Chiedi a FixBot
      Aggiungi Commento
      • Place an old cloth inside the drum to assist with scrubbing during the wash.
      • Add around 100 grams of citric acid plus two dishwasher tablets directly into the drum or detergent compartment.
      • Select a high-temperature cycle (up to 95°C) with a high water level setting if available.
      • Allow the machine to complete this cycle to dissolve any leftover cleaner and rinse the entire system.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cleaning these key areas ensures your washing machine performs effectively and lasts longer. Always reference the manufacturer’s instructions for model-specific details. Consistent maintenance keeps clothes smelling fresh and prevents unnecessary wear on your machine.
Ula Gantar
Membro da: 01/08/25
16.609 Reputazione
81 guide realizzate
ZEOS Slovenia Membro di ZEOS Slovenia
Local Repair Groups
2 Membri
588 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 115
Tutti i Tempi: 1,165
