Salta al contenuto principale
Hover-1 XLS Ignition Replacement
Cosa ti serve
    1. Hover-1 XLS Ignition Replacement, Ignition: passo 1, immagine 1 di 1
      • Remove the six 16mm #3 Hex head screws located on the front panel.
      • The screws are held in with Teflon tape, so use a chemical remover like B'laster to loosen the screws.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hover-1 XLS Ignition Replacement: passo 2, immagine 1 di 3 Hover-1 XLS Ignition Replacement: passo 2, immagine 2 di 3 Hover-1 XLS Ignition Replacement: passo 2, immagine 3 di 3
      • Grab the front panel and gently lift it up to the side.
      • The front panel is connected to the ignition, so don't pull too hard or the wires will get damaged.
      Chiedi a FixBot
      Aggiungi Commento
    3. Hover-1 XLS Ignition Replacement: passo 3, immagine 1 di 1
      • Remove the two, 19 mm Phillips #2 screws holding the ignition.
      • Remove the yellow and red wires that are connected to the ignition. To remove them, look at the soldering guide provided by iFixit.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team S1-G2, White Winter 2019 Membro di Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Membri
31 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 39
Tutti i Tempi: 1,653
