Salta al contenuto principale
Hover-1 XLS Battery Replacement
Cosa ti serve
    1. Hover-1 XLS Battery Replacement, Battery: passo 1, immagine 1 di 3 Hover-1 XLS Battery Replacement, Battery: passo 1, immagine 2 di 3 Hover-1 XLS Battery Replacement, Battery: passo 1, immagine 3 di 3
      • Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
      • There are four screws that need to remove. Two on one side and the two on the opposite side.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hover-1 XLS Battery Replacement: passo 2, immagine 1 di 3 Hover-1 XLS Battery Replacement: passo 2, immagine 2 di 3 Hover-1 XLS Battery Replacement: passo 2, immagine 3 di 3
      • Remove the adhesive holding the wires tightly.
      • You can use a sharp object to score the adhesive before pulling.
      • Pull on both sides of the wire connections.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S1-G2, White Winter 2019 Membro di Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Membri
13 guide realizzate
17Commenti sulla guida
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David Schultze - Rispondi Condividi
David did you happen to find one? Please let me know I've been looking for one
Michael Hawk - Rispondi Condividi
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
GutZ Era - Rispondi Condividi
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
Batman and King - Rispondi Condividi
Hi, where can you find the battery replacement? I have my scooter and the battery needs to be replaced.
Mary - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 5
Ultimi 7 giorni: 39
Ultimi 30 giorni: 215
Tutti i Tempi: 14,396
