Salta al contenuto principale
Hover-1 Horizon Left Balancing Sensor Replacement
Cosa ti serve
    1. Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: passo 1, immagine 1 di 2 Hover-1 Horizon Left Balancing Sensor Replacement, Base Plate: passo 1, immagine 2 di 2
      • Remove the six 12mm Phillips #2 screws holding the base plate.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hover-1 Horizon Left Balancing Sensor Replacement: passo 2, immagine 1 di 2 Hover-1 Horizon Left Balancing Sensor Replacement: passo 2, immagine 2 di 2
      • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
      Chiedi a FixBot
      Aggiungi Commento
    3. Hover-1 Horizon Left Balancing Sensor Replacement: passo 3, immagine 1 di 3 Hover-1 Horizon Left Balancing Sensor Replacement: passo 3, immagine 2 di 3 Hover-1 Horizon Left Balancing Sensor Replacement: passo 3, immagine 3 di 3
      • Remove the base plate by lifting it up.
      • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
      Chiedi a FixBot
      Aggiungi Commento
    1. Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: passo 4, immagine 1 di 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: passo 4, immagine 2 di 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Gyroscope Sensor Board: passo 4, immagine 3 di 3
      • Remove the two connectors on either side of the board by lifting the tab and pulling out.
      • Remove the connector in the middle of the board by squeezing the tab and pulling up.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hover-1 Horizon Left Balancing Sensor Replacement: passo 5, immagine 1 di 2 Hover-1 Horizon Left Balancing Sensor Replacement: passo 5, immagine 2 di 2
      • Remove the four 11mm Phillips #1 screws that hold the cover on.
      Chiedi a FixBot
      Aggiungi Commento
    3. Hover-1 Horizon Left Balancing Sensor Replacement: passo 6, immagine 1 di 3 Hover-1 Horizon Left Balancing Sensor Replacement: passo 6, immagine 2 di 3 Hover-1 Horizon Left Balancing Sensor Replacement: passo 6, immagine 3 di 3
      • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
      • Lift the board to reveal the connections on the bottom.
      Chiedi a FixBot
      Aggiungi Commento
    4. Hover-1 Horizon Left Balancing Sensor Replacement: passo 7, immagine 1 di 2 Hover-1 Horizon Left Balancing Sensor Replacement: passo 7, immagine 2 di 2
      • Remove the middle connector by squeezing the top of the tab and pulling up.
      Chiedi a FixBot
      Aggiungi Commento
    5. Hover-1 Horizon Left Balancing Sensor Replacement: passo 8, immagine 1 di 3 Hover-1 Horizon Left Balancing Sensor Replacement: passo 8, immagine 2 di 3 Hover-1 Horizon Left Balancing Sensor Replacement: passo 8, immagine 3 di 3
      • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
      • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
      Chiedi a FixBot
      Aggiungi Commento
    6. Hover-1 Horizon Left Balancing Sensor Replacement: passo 9, immagine 1 di 3 Hover-1 Horizon Left Balancing Sensor Replacement: passo 9, immagine 2 di 3 Hover-1 Horizon Left Balancing Sensor Replacement: passo 9, immagine 3 di 3
      • Unclip the black connector by squeezing both sides and pulling them apart.
      Chiedi a FixBot
      Aggiungi Commento
    1. Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: passo 10, immagine 1 di 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: passo 10, immagine 2 di 3 Hover-1 Horizon Left Balancing Sensor Replacement, Left Balancing Sensors: passo 10, immagine 3 di 3
      • Remove the three 10 mm Phillips #1 screws connecting the balance sensor to the hoverboard.
      • The balance sensor tabs are made of sensitive rubber. Screw them back on slowly, and do not over-tighten.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hover-1 Horizon Left Balancing Sensor Replacement: passo 11, immagine 1 di 2 Hover-1 Horizon Left Balancing Sensor Replacement: passo 11, immagine 2 di 2
      • Remove the sensor tab by carefully lifting it away from the hoverboard.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Jesus
Membro da: 10/08/18
85 Reputazione
Una guida realizzata
Cal Poly, Team S13-G6, White Fall 2018 Membro di Cal Poly, Team S13-G6, White Fall 2018
CPSU-WHITE-F18S13G6
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 11
Ultimi 30 giorni: 41
Tutti i Tempi: 1,600
