Salta al contenuto principale
Hover-1 H1 Power Button Replacement
Cosa ti serve
    1. Hover-1 H1 Power Button  Replacement, Bottom Shell: passo 1, immagine 1 di 1
      • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hover-1 H1 Power Button  Replacement: passo 2, immagine 1 di 1
      • Puncture the two black stickers by using the tip of a screwdriver.
      • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
      Chiedi a FixBot
      Aggiungi Commento
    3. Hover-1 H1 Power Button  Replacement: passo 3, immagine 1 di 2 Hover-1 H1 Power Button  Replacement: passo 3, immagine 2 di 2
      • Lift each side of the bottom shell by pulling up.
      • When lifting the shell, take care to not tear any cables from their connectors.
      Chiedi a FixBot
      Aggiungi Commento
    4. Hover-1 H1 Power Button  Replacement: passo 4, immagine 1 di 1
      • Unplug the battery by pulling gently on both sides of the orange connector.
      Chiedi a FixBot
      Aggiungi Commento
    1. Hover-1 H1 Power Button  Replacement, Power Button: passo 5, immagine 1 di 1
      • Unplug the power button connector by pinching the tab on the front and pulling directly upwards.
      • Pull the cable through the center section of the hoverboard.
      • For reassembly, you will have to feed the cable back through the center section. This can be done using a rigid wire or cable.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hover-1 H1 Power Button  Replacement: passo 6, immagine 1 di 2 Hover-1 H1 Power Button  Replacement: passo 6, immagine 2 di 2
      • Using an adjustable wrench, remove the nut on the back of the power button by rotating the nut counterclockwise.
      Chiedi a FixBot
      Aggiungi Commento
    3. Hover-1 H1 Power Button  Replacement: passo 7, immagine 1 di 1
      • Pull the power button through the hole in the shell.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team S17-G6, White Fall 2018 Membro di Cal Poly, Team S17-G6, White Fall 2018
CPSU-WHITE-F18S17G6
4 Membri
58 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 9
Ultimi 30 giorni: 38
Tutti i Tempi: 4,096
