Salta al contenuto principale
Hot Tools HPK12 Control Assembly Replacement
Cosa ti serve
    1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: passo 1, immagine 1 di 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: passo 1, immagine 2 di 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: passo 1, immagine 3 di 3
      • Remove round plastic cover near cord base by prying under the side with the metal spudger.
      • Flip the device and remove the other round plastic cover near the base of the cord.
      • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hot Tools HPK12 Control Assembly Replacement: passo 2, immagine 1 di 1
      • Use the metal spudger to push the center pin through to the other side.
      Chiedi a FixBot
      Aggiungi Commento
    3. Hot Tools HPK12 Control Assembly Replacement: passo 3, immagine 1 di 2 Hot Tools HPK12 Control Assembly Replacement: passo 3, immagine 2 di 2
      • Lift back plastic cover to expose spring assembly.
      • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
      • Grip the exposed end of the spring assembly and remove it.
      • The side with the two ends of the spring goes into the recessed area of the iron
      Chiedi a FixBot
      Aggiungi Commento
    4. Hot Tools HPK12 Control Assembly Replacement: passo 4, immagine 1 di 1
      • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
      Chiedi a FixBot
      Aggiungi Commento
    5. Hot Tools HPK12 Control Assembly Replacement: passo 5, immagine 1 di 3 Hot Tools HPK12 Control Assembly Replacement: passo 5, immagine 2 di 3 Hot Tools HPK12 Control Assembly Replacement: passo 5, immagine 3 di 3
      • Lift upward on the control assembly cover to remove it from the flat iron base.
      • Remove dial and switch cover and set aside.
      Chiedi a FixBot
      Aggiungi Commento
    6. Hot Tools HPK12 Control Assembly Replacement: passo 6, immagine 1 di 3 Hot Tools HPK12 Control Assembly Replacement: passo 6, immagine 2 di 3 Hot Tools HPK12 Control Assembly Replacement: passo 6, immagine 3 di 3
      • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
      • Lift the backing plate upwards to remove it from the flat iron.
      • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
IUPUI, Team 3-4, Baechle Fall 2016 Membro di IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 32
Tutti i Tempi: 3,221
