Introduzione
The suction motor is at the core of the proper function of any household floor cleaner. This guide will demonstrate how to properly replace a broken suction motor.
Cosa ti serve
Lay the cleaner down horizontally with its wheels closest to the floor.
Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
Unscrew two screws using Phillips #2 screwdriver.
Detach grey piece from vacuum.
Altre 4 persone hanno completato questa guida.
1Commento della guida
What to do if the motor is still good but the cooling fan on the top of the armature has broken off?
