Salta al contenuto principale
Hoover Power Path Pro Advanced Power Switch Replacement
Cosa ti serve
    1. Hoover Power Path Pro Advanced Power Switch Replacement, Power Switch: passo 1, immagine 1 di 1
      • Remove the lower brushroll from the bottom of the cleaner.
      Chiedi a FixBot
      Aggiungi Commento
    2. Hoover Power Path Pro Advanced Power Switch Replacement: passo 2, immagine 1 di 1
      • Use a long #2 Philips head to remove the 8 numbered screws on the bottom of the cleaner (They will also be indicated on the bottom of the vacuum).
      Chiedi a FixBot
      Aggiungi Commento
    3. Hoover Power Path Pro Advanced Power Switch Replacement: passo 3, immagine 1 di 2 Hoover Power Path Pro Advanced Power Switch Replacement: passo 3, immagine 2 di 2
      • Pull the red handle to remove the front suction unit from the cleaner.
      Chiedi a FixBot
      Aggiungi Commento
    4. Hoover Power Path Pro Advanced Power Switch Replacement: passo 4, immagine 1 di 1
      • Unscrew the hose by using a Phillips #2 to detach it from the top cover of the cleaner.
      Chiedi a FixBot
      Aggiungi Commento
    5. Hoover Power Path Pro Advanced Power Switch Replacement: passo 5, immagine 1 di 2 Hoover Power Path Pro Advanced Power Switch Replacement: passo 5, immagine 2 di 2
      • Push down on the handle release button. Lift the edge of top cover connected to this button.
      • Repeat the above step for the "On/Off" button.
      • Pull entire top cover off.
      • Caution: when pulling the handle release button, make sure the top of the cleaner does not fall.
      Chiedi a FixBot
      Aggiungi Commento
    6. Hoover Power Path Pro Advanced Power Switch Replacement: passo 6, immagine 1 di 1
      • Remove the "On/Off" cap by pulling it upwards with caution.
      Chiedi a FixBot
      Aggiungi Commento
    7. Hoover Power Path Pro Advanced Power Switch Replacement: passo 7, immagine 1 di 1
      • Use a long #2 Philips head to remove the two screws from the arched grey piece.
      Chiedi a FixBot
      Aggiungi Commento
    8. Hoover Power Path Pro Advanced Power Switch Replacement: passo 8, immagine 1 di 2 Hoover Power Path Pro Advanced Power Switch Replacement: passo 8, immagine 2 di 2
      • Pull out the red power the red power switch.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 4 persone hanno completato questa guida.
3Commenti sulla guida
What is the part number?
martahayner - Rispondi Condividi
Thanks so much!!
debmccrimm - Rispondi Condividi
you have to test the switch, mine tested ok which led me to the fuse between the motor and switch. It was bad, parts warehouse part # 440004065 does the trick.
frank - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 51
Tutti i Tempi: 4,363
