Salta al contenuto principale
Hoover Power Path Pro Advanced Hose Replacement
Cosa ti serve
  1. Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: passo 1, immagine 1 di 2 Hoover Power Path Pro Advanced Hose Replacement, Brush Roller: passo 1, immagine 2 di 2
    • Unplug the vacuum cleaner from the wall outlet before starting. Make sure the water tanks are empty.
    • Lay the cleaner down horizontally with its wheels closest to the floor.
    Chiedi a FixBot
    Aggiungi Commento
  2. Hoover Power Path Pro Advanced Hose Replacement: passo 2, immagine 1 di 2 Hoover Power Path Pro Advanced Hose Replacement: passo 2, immagine 2 di 2
    • Hold the lower brush roll with both hands and pull outwards until it is detached.
    Chiedi a FixBot
    Aggiungi Commento
  3. Hoover Power Path Pro Advanced Hose Replacement: passo 3, immagine 1 di 1
    • Unscrew the 6 marked screws using a Phillips #2 head screwdriver.
    • Remove the brush roller.
    Chiedi a FixBot
    Aggiungi Commento
  4. Hoover Power Path Pro Advanced Hose Replacement, Hose: passo 4, immagine 1 di 1
    • Use a long #2 Philips head screwdriver to remove the 8 numbered screws on the bottom of the cleaner.
    • They will also be indicated on the bottom of the vacuum.
    Chiedi a FixBot
    Aggiungi Commento
  5. Hoover Power Path Pro Advanced Hose Replacement: passo 5, immagine 1 di 2 Hoover Power Path Pro Advanced Hose Replacement: passo 5, immagine 2 di 2
    • Pull the red handle shown to remove the front suction unit from the cleaner.
    Chiedi a FixBot
    Aggiungi Commento
  6. Hoover Power Path Pro Advanced Hose Replacement: passo 6, immagine 1 di 1
    • Unscrew the Phillips #2 screw at the bottom of the hose.
    Chiedi a FixBot
    Aggiungi Commento
  7. Hoover Power Path Pro Advanced Hose Replacement: passo 7, immagine 1 di 1
    • Grab the attachment at tip of the hose and unscrew it. Pull outwards on the hose until completely removed.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
4Commenti sulla guida
Where can I find this replacement hose?
Jennifer - Rispondi Condividi
Complete waste of $$, won’t pick up water unless you apply about 40 lbs of downward force on the %#*@ thing, I tried all the trouble shooting tips, no change, maybe used 3 times. The attachment same thing nada. Basically a toy.
Leigh Robert Smith - Rispondi Condividi
Where can I purchase the lower hose?
Eryk H. - Rispondi Condividi
I've been trying to find the hose for mine for two years now I even called hoover and they tell me it's unavailable maybe I need to find a Hoover scrap yard lol if anyone knows where I can get one please let me know via email at jefferyalger1959@gmail.com
Jeffery Alger - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 13
Ultimi 30 giorni: 31
Tutti i Tempi: 5,121
